humm..is that the reason ppl use some other setup instead of the LS style compressor? I was planning on using one for my swap. I thought i read its a clutchless something design that never turns off and you cant use it on OBS style AC head units lol
1991 Silverado ECLB
LM7-T56
The Corvette inspired Silverado is now rolling strong!
http://www.ls1truck.com/forums/lsx-t...silverado.html
I'll have to do some digging for the frame pics but yes, you'll have to cut and fit a piece to go in and you'll find out the F-body A/C compressor is a bitch to fit in that hole. I went with a 5.3/6.0 compressor to get the fittings on the side and machined an extra groove in the harmonic balancer for belt alignment. With the F-body A/C lines going out the back you'll have to cut about 3 1/2" to 4" out of your cross member and a hell of alot more out of the frame rail. The A/C setup is the hardest part of the installk if you ask me. If you're looking for a challenge notch the frame. If you want to make life easy, use the S&P relocator kit. They will both work well in the end.
97 GMC, 2002 LS6.
1991 GMC Syclone #1428
The pictures are small but you'll get the idea.
97 GMC, 2002 LS6.
I agree with NITROUS. I mounted mine like nitrous is talking about. I wanted the factory look and didnt want to spend the $ for the S&P setup. I also wanted my motor as low and as far back as possible. Now that it is done I like it but if I had it to do again it would be up top. Way too much time and money to put it down low and you cant see any of it. It will also be tough if you ever have to get the compressor off. But....it does look good. Good luck.![]()
i can see that im really glad the way mine is done without the frame notch.
thats a huge notch![]()
