Results 1 to 6 of 6
Thread: 411 PCM MIL Circuit & Serial Data Wires
    Sep 2009
    NE Ohio
    I thought I saw on ALLDATA that the MIL light came out of the PCM.
    But I dont see it. How does the check engine light get the signal?
    I see that the PCM has 2 data wires. Class 2 Serial Data & ECM/PCM/VCM Class 2 Serial Data. I am assuming that the 2nd one is communication between those 3 modules, correct?
    Im starting to thin out the wires that I dont need as I have the whole engine harness separated for each component.
    Thanx
    Been lurking since 09 and I finally have my kickass 6.0 LQ4
    LQ4 LQ9 6.0L Engine Service Manual Save to your computer in case it disappears
    pin 58 on the blue connector which is a green wire should be the OBD2 serial wire. MIL is pin 46 on the red connector should be brown and white wire
    Long Beach California
    +1 above. worked perfect for me. im sure you have gone through the site but just in case heres a couple links that will help
    this is how to hook up your ob2 connector http://lt1swap.com/fuseblock_obd2port.html
    this proves pin 58 on BLUE connector is dk green for the serial data http://lt1swap.com/2000harness.htm
    and this is for all other pin outs for 99-02 pcm's (since yours is an 01' correct?) http://lt1swap.com/99-02_vortec_pcm.htm
    Sep 2009
    NE Ohio
    Quote Originally Posted by gta87305 View Post
    Quote Originally Posted by kewljay223 View Post
    Thanx guys. I had forgotten about LT1swap.com. I have multiple bookmarks on my computer and didnt even see them.
    NP man. im sure we have all been there. i sure have. and the funny thing is that as you find more and more info that you know you will need to refererance again so you bookmark them, and before you know it youve got so many bookmarks that it just ends up making things worse than before!! lol. anyway, good luck!
    Sep 2009
    NE Ohio
    NP man. im sure we have all been there. i sure have. and the funny thing is that as you find more and more info that you know you will need to refererance again so you bookmark them, and before you know it you've got so many bookmarks that it just ends up making things worse than before!! lol. anyway, good luck!
    Exactly. Or you just get to where I was and completely forget. Between ALLDATA and LT1SWAP and various others. Makes my head spin. But I am glad I tore the harness apart because now it has all fallen in to place as to how to make it work.
