Results 1 to 10 of 21
Thread: Stall Converter Question
    Muskogee, OK
    I wanted to pick everyone's brain about what to do about a TC. I drive a '05 SS with AWD and I'm leaning towards a bigger stall. I've read a lot on here about the size of the TC affecting the trans temp. I was thinking about going with about a 10.5 Circle D with about a 3000 stall. The tranny has a shift kit and I was wondering if that size stall would fall in the grey area of performance and longevity. I guess I'm assuming a higher stall will put more strain on the trany on top of it being AWD. Is this assumption wrong? I would really like to go with a higher stall but I know how weak these 65e's can be.
    2005 AWD Silverado SS-CAI, Shorties, X pipe, SLP Loudmouth II, HD2 Shift kit, Corvette servo, tru-cool 40k, Yank SS3600, 160 Stat, Nelson tune.
    Our trucks need larger transmission coolers regardless of modifications. So definitely upgrade if you haven't already. One large trans cooler should be fine for that converter.
    3000 isn't too loose and should perform well.
    Muskogee, OK
    Thanks for the info Allen. I'll for sure add a bigger cooler before the TC goes in.
    Aug 2012
    Mount Pleasant, Tx
    So even with a 2600 stall in my daily should I be running a 40K cooler? or am I fine with the factory cooler?
    2000 GMC Sierra 1500 RCSB 2wd - 454 LSX powered drag truck...
    Arizona/Utah
    Quote Originally Posted by jmgak47 View Post
    Yes you should get a bigger cooler. A 40k is a great option factory isn't enough in my stock truck.
    Aug 2012
    Mount Pleasant, Tx
    Have one on order. Thx, wasn't sure but always better safe then sorry.
