Results 1 to 10 of 12
Thread: Help!!! Novak ac
    Rockwall, TX
    Exclamation Help!!! Novak ac
    Just tried to install my Novak ac bracket and in the directions it says to flip the belt tensioner 180 degrees and counter sink a bolt on the water pump...
    Tried that and it's a no go.
    So my question is, is there a diff tensioner I could use?? Or am I going to have to get a diff water pump to where the tensioner is not hitting the water pump??
    Any info is appreciated!
    1989 RCSS 5.3/4L60E swap
    - 224/230 .581.591 112lsa,
    - 3200 Stall
    - DJM 4/6 drop
    - Nelson Tuned
    Building the truck GM never did..
    Jul 2010
    Douglasville Ga
    Its been a little while, but I have installed a Novak kit. I remember countersinking a bolt and having to grind FOREVER on the backside of the tensioner. Good luck.
    Birmingham, AL
    is it designed for the truck accesories/water pump or the car stuff??
    01 Silverado
    Rockwall, TX
    on the novak site it says made for the gen III 4.8,5.3,6.0 vortec motors with truck accesories.
    i wonder if i can get a diff tensioner?
    or do they even have anotherone
    - 3200 Stall
    - DJM 4/6 drop
    - Nelson Tuned
    Jul 2010
    Douglasville Ga
    It just takes ALOT of grinding. I mean ALOT. But it works.
    This is timely. I just finished grinding mine. Use a cutoff wheel. Aluminum will clogg up a stone or grinding tip. It will fit after removing enough material. My problem is the tension is opposite of what they want. The spring and cup will only go in one way and I can't see how the tension will be correct. I'm thinking there must be another tensioner with different clocking.
    Steve
    66 Chevelle, 454, 200r4, 12.9's, 86 K5 with 5.3
    Rockwall, TX
    finally got it together.... with a good 1/4 inch of my tensioner removed...
    and stevebbc i didnt think it was gonna work eaither untill it was time to put the belt on and it worked out fine
    ill post pics later on
    - 3200 Stall
    - DJM 4/6 drop
    - Nelson Tuned
    Jul 2010
    Douglasville Ga
    Good deal!
    T-shark, when I bolt up the pulley that came with the kit, the washer and bolt lock it up so it won't turn. Also, the bearing shaft for the pulley only goes about half way thru the pulley bearing. What did you do?
    Steve
    Steve
    Rockwall, TX
    idk man my pulley worked out fine, i just have a problem with my compressor not lining up with all my other acc so the belt keeps hopping around the tensioner..... this kit is pi@%ing me off
    - 3200 Stall
    - DJM 4/6 drop
    - Nelson Tuned
