Results 1 to 10 of 13
Thread: Comp Cams 212/218 LSx Cam "HIGH LIFT"?????????
    Mar 2011
    Dade County , Fl
    What converter should be used with this cam
    These Xtreme RPM cams from COMP Cams have been designed to increase horsepower and extend the rpm range of your engine. From stock replacements to ultimate performance, there is an Xtreme RPM cam to meet your performance goals.
    :Specifics:
    # Basic Operating RPM Range: 1,500-6,800
    # Duration at 050 inch Lift: 212 int./218 exh.
    # Valve Lift with Factory 1.7:1 Rocker Arm Ratio: 0.558 int./0.563 exh. lift
    # Lobe Separation (degrees): 115
    # Grind Number: LS1 XR265HR-15
    Can be used without a converter, but a 2800 or so would really be nice.
    Dec 2008
    san antonio TX
    thats a small cam id get a higher lift and more dur
    Thats the cam im currently running, cam works well with stock converter. I had it behind a tb stall, worked well also. Now I have a PI 3600 stall and I like it the most with this converter.
    03' Silverado RCSB H/C 5.3, 4L80,76mm KBracing Kit
    13' Sierra Denali 2500HD CCSB 4x4
    Mar 2007
    Newark, Delaware
    Quote Originally Posted by graysilverado5.3 View Post
    Even the stock cam would perform better with a 3600 stall. The real questions are how do you use your truck and what are your goals with it?
    Big slow mud truck with a TUNE!!!!!!
    Mar 2011
    Dade County , Fl
    Quote Originally Posted by Beatdown Z View Post
    Well the truck is going to be used ever day to go to work and some time little long trips on the high way about 90 a month. Just want a cam to chop a bit nothing crazy. Not looking for to much hp just a nice sound to the motor
