Results 1 to 10 of 32
Thread: 2002 chevy, 4.3 to 5.3 swap...
    here is the start to my swap thread. no pics yet but some info. pics soon to come, maybe tomorrow.
    i bought a 2002 suburban, for a parts truck to make the install ez'r.
    here is what in goin to use.
    5.3
    harness
    computer
    motor mounts
    fuel lines
    exhaust(unless i get LPP long tubes before the swap)
    other stuff that i might need, this will be my first swap so i figured i waould buy a complete donor vehical just incase.
    i might make another thread on swapping the complete LT interior over and to also to keep this a motor only thread.
    59 chevy apache>old school rod with 5.3.
    92 chevy swb>full frame, bagged, 98 interior swap.
    02 chevy swb>LT interior swap.
    01 tahoe> lowered on big wheels, family ride.
    97 ford diesel>big turbo,injectors,oil pump,etc.
    85 stang coupe> black on black, H/C/I.
    Hutto TX
    Sounds like a solid plan. Can't go wrong with the entire vehicle in your backyard or garage. You should be able to take the entire "C1" and "C2" blocks or whichever ones you need out of the back of your original under hood junction block and "reinstall" the 5.3 "C"-blocks into the UJB on your truck, so as to not cut any factory wires for the 5.3 harness. Good luck!
    Dig the HD hood.
    Got any pics of the 92 swapped interior? (currently fiddling with 95 swap in my 91)
    1991 Silverado ECLB
    LM7-T56
    that will be an easy swap for you because you have the entire vehicle. A year or so back I did the 4.3 to 5.3 in my 2000 truck and it wasnt too bad, just didnt have everything
    thanks guys, from what ive read its all plug n play...
    heres my 5.3, its still in the burb. hope to have it out this weekend.
    here the 92 interior r6z406....
    lol make sure you clean everything before you get it in.
    wichita falls, tx
    oh good call on getting a whole donor truck...that will make for a simple swap....and less trips to the salvage yard...good luck man if u have questions feel free to pm me....ive been down this road before
    Intro Radicalli's
    lol yea thats a must, i have to have a nice clean engine.
    Quote Originally Posted by banker099 View Post
    im sure i will be hitting you up, was there anything that you had to do that was un expected.
    ive hard that since im using the 5.3 computer than i need to install the steering colum out of the same vehical because of the anti-theift bs in the ignition. true or false??
    wichita falls, tx
    i would just have the pcm tuned and have the vats turned off...much easier
    Intro Radicalli's
    hmmm will i have to take the pcm to the tuner before hand to get it tuned and get the vats turned off so i can even start the truck after the swap correct?
    i was just planning on a dyno tune.
    edit: i just called a tuner, he said to bring in my pcm and he will turn off the vats for $100
    wichita falls, tx
    yep...vats has to be turned off before it will start
    Intro Radicalli's
