Results 1 to 10 of 20
Thread: Driveline Vibration Part 2
    Needville,TX
    Ok I going to solve this problem once and for all...I hope.
    The only thing original on the truck since the old setup is the rearend and drop kit but playing with the pinion angle seems to change the vibration intensity.
    Right now its set at maybe -1* on the trans/eng and the rearend is -3to4* pinion angle.
    The vib is really noticable now at this setting at the speed of 65-70mph and the faster you go I guess the harmonics of it change and it smooths out.
    Look at the crappy way DJM adj. pinion angle...
    89' GMC RCSB 6.0L LQ4, T56, 4.56 Gears
    S.A. Texas
    I am having the same problem, i am just trying different shims looks like i need the 2* shims
    Needville,TX
    Quote Originally Posted by murdered_outgmc View Post
    Well at least I can say Im not the only one with this problem. Only thing is mine doesnt use shims.
    Whats ur lowering setup?
    Racoon Twp., PA
    I would take off that clamp style flip quick and weld some perches on there. That thing is gonna spin and break stuff.
    2013 CC 5.3
    81 C10 LS1 project
    Winnipeg, Manitoba, Canada
    Quote Originally Posted by tanz45 View Post
    X2, thats a pretty 'ugly' flip kit... Make sure you know your angles for sure (dont guess).
    Jun 2007
    maine
    hey man any progress lately??? i finally had time this morning to throw mine up on 4 cylinder blocks on the garage floor and measure out my pinion angle. currently my Transmission is sitting at -2 degrees and my rear end is at a positive 5 degrees. i want the driveline angle to be at -2 degrees so im 5 degrees out of wack on the rear end and already have a 4 degree shim in there. im hoping this is whats causing my vibrations which is only muliplied by that fact that i have 4:56 gears and the shaft is turning pretty fast. do you have any idea if CalTracs allow you to adjust pinion angle? or how the heck your supposed to compensate for being so many degrees off. thanks bud hope all is well with the truck!
    Hutto TX
    Was the vibe present before the swap?
    Checked the tires/wheels for out of balance?
    Have you put it on jackstands yet????
    Compared to Wtfan, your pinion angle is in the money. Sounds like if you shimmed your tranny UP to the 3* to match teh rear, then they would be parallel but opposite....like they should be. I think you have another issue other than the pinion angle.
    1991 Silverado ECLB
    LM7-T56
    Round Rock, TX
    Quote Originally Posted by r6z4o6 View Post
    Hey whats up, are you in Hutto... I drive through Hutto everyday atleast twice.
    Hutto TX
    Yeppers, offa 1660 north. I get on Chandler road and zip to Georgetown to get to work everyday. Where is your shop located at????
    1991 Silverado ECLB
    LM7-T56
    Round Rock, TX
    I live in Round Rock off Sam Bass and my shop is in Circleville..just north of Taylor off 1331 next to the Lake. Right across the street from the water treatment plant..
