Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 36
Thread: 79 k5
    79 k5
    hey guy's i'am doing a 5.3 4l60e swap and need all the help i can get on how to convert my harness to stand alone. i really want to takle the harness myself. by the way i have every wire for the motor and harness is there up to the junction box plug. your help will be appreciated. my fuel will come from a modified 91 sending unit. thanx!!!!
    here are some pics of the old rust bucket . the engine and trans are in . modified the 91 sending unit with a 01 tahoe fuel pump works great. the truck needs work,but i need to get it on the road first. thinkin about black with some torque thrust.
    Dec 2008
    san antonio TX
    man i wish i could help, but im going through the same thing you are. i really dont want to spend $650 on an engine harness so im going to try to make the harness stand alone.
    Anaheim Hills, CA
    You can dissect the harness fairly easy. You just need to know what plugs/connectors need to stay in the harness to make sure your motor wont throw a code after you re-tune the ECM. Your tuner will need to know all the details, so they can tune accordingly. A wiring diagram will show every pin number and color on the ECM. Just remove one by one untill your done. Re-loom the harnes, plug it all back together and your done. I have done this one time with my last build. I had a 2000 LS1 that I put into a full tube chassis, custom offroad truck. I had the mail order tune done by "Wait 4 Me Performance" in Texas for $75.00 a couple of years ago. Go for it, and good luck!!
    ...........Workin' on it...........
    Anaheim Hills, CA
    ..........And I will be going through this again in the next few months. I have a 5.3 from an '08 Suburban going into a '72 Blazer. I will do the whole thing again myself just because I am a cheap ass, and cant spend the $700 for someone alse to do it. You can have the wiring done in a day doing it your self and taking your time. Just search for the "Minumum" connectors needed in the harness. I want to say:
    knock sensors
    o2 sensors
    cam position sensor
    throttle position sensor
    injectors
    coil packs
    Intake air sensor
    Thaere might be more, but off the top of my head, at 6am, that all I can think of.
    Dec 2008
    Hugo, Ok
    you dont need 02 senors do you?
    thought that was just in new rides you had to have em on.
    Norman, OK
    what about water temp sensor?
    Does the ECU use water temp or air temp for cold weather fuel correction?
    Anaheim Hills, CA
    I dont remember having that, but I could be wrong. I think the air intake sensor will tell the ECM what it needs to in order for the correct amount of air/fuel mixture. I used all seperate sensors and controls for the water temp, oil pressure, electric fan relays, fuel pump, etc. I wanted the absolute minimum in the wiring harness.
    Anaheim Hills, CA
    Yes, the o2 sensors tell the ECM how the fuel is burning, rich or lean.
    Dec 2008
    Hugo, Ok
    oh i was thinkin you could take off all the emissions stuff completely off. cuz ya o2 go in ya exhaust and ive seen em with wires cut and it runnin fine
