Results 1 to 9 of 9
Thread: What sensors?
    SE Georgia
    What sensors?
    Which sensors do I need to pull off my old motor to go on the 5.3? I am thinking I need the oil pressure sensor (located next to the distributor) and the temp sensor ( on the old thermostat cover) But what else do I need? Also I am thinking I have to drill and tap the waterpump to accept the temp sensor right?
    Tired ol' 5.7, 5.3 swap in progress
    Handle every stressful situation like a dog.
    If you can't eat it or hump it.
    Piss on it and walk away.
    May 2004
    You should have 1 temp sensor on the side of the block. Move it to the rear passenger head. Pull the plug out and tap it to the sensor size. No need to tap the water pump. The oil pressure switch on the back of the block can be installed on the oil cooloer block off plate by the filter. You'll figure it out once you look at it. Don't forget you're fuel pump wiring is in the oil pressure switch so don't remove those wires, keep them like they are. Sometimes members like to drill the top of the water pump for the throttle body heater hose but I just plugged mine be cause it's a waste of space and the air will work it's way to the radiator since it's higher than the heads. Feel free to do as you wish but I guarantee you don't need it and it won't hurt the heads.
    Good Luck!
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    SE Georgia
    There is already one temp sensor on the back passenger block what is it and should I just remove it? With the oil pressure sensor I broke the one off the 5.3 originally so I am just going to drill and tap what is left and put the one off the 5.7 there.
    May 2004
    You need to put the 96 sensor in the rear of the passenger head for your gauges. The one on the block is for the pcm so you have to run 2 of them.
    97 GMC, 2002 LS6.
    Kentucky
    I never had a chance yet to check because it won't run, lol, but do we have to keep the 5.3 oil pressure hooked up to start or is it ok to just run the factory oil pressure for the gauges.
    I used S&P's adapters for the temp and oil pressure. For the temp you will need the 12mm adapter and oil pressure is I believe 16 mm. I'll try to find the packages for the part #'s
    1996 GMC extended cab, 2003 5.3/auto
    SE Georgia
    As far as tapping the head I am going to need to have it off the truck right?
    May 2004
    aarolar, you can get the adapter from S&P but your temps will be off. I think mine are off close to 12 degrees. But to answer your question yes, you'll need to pull the head off the truck unless you have a short angle drill.
    468Blazer, keep the 5.3 switch hooked up also for the pcm.
    97 GMC, 2002 LS6.
    Jun 2007
    maine
    Quote Originally Posted by aarolar View Post
    WELL did you already put the motor in??? my motor was on a stand when i did it. but other wise yes you will have to take the head off.. and the gm head bolts arent reusable as i was told on here so i bought the ARP ones anyways for 180$ rated for nitrous and they are reusable... maybe a the route to go. you may as well just pull both clean everything, have the heads resurfaced and then youll know for sure its all been gone through. also if your doing a cam its probably going to be easier to swap the springs and stuff with them off. take your time bro otherwise in a month you will find yourself taking stuff apart again to add mods or w/e else its just easier to do at the start then when EVERYTHING is clean and plugged in and buttoned up... just my 2 cents. i tapped my head and as far as i can tell the motor never gets past 160 degrees. so im assuming its pretty darn close.
    SE Georgia
    Quote Originally Posted by Wtfan18 View Post
    Yeah I have the heads off and cleaned so no problems with any of that.
