Results 1 to 10 of 12
Thread: 1980 k10 lq4/4l80e
    1980 k10 lq4/4l80e
    So I think I'm going to start a new thread with what I've actually done and will be doing to my truck... Hopefully I can get some pic on here from my phone...
    It's a 2003 2500HD ENGINE/ TRANS...
    Here is kind of a quick list of what my dad and I have done to the truck before the decision of 6.0 swap..
    Box/cab off sandblast frame paint
    Energy susp cab/ body mounts
    Eaton posi in rear
    New brakes
    My dad fixed all the body work
    Two new fuel tanks
    New fuel lines / switching valve
    New exhaust
    4 in lift. Susp. Not blocks but extra leaves
    Rancho 4 in lift shocks
    Pro comp mud terrain 35s
    New front finders inner outer
    Need bars
    My dad adapted under truck so are mount
    Now I'm in the process of reworking the wiring harness In my basement and searching for an np205. Unless there hd a better option..
    Oh my dad and I fabbed up some motor mounts
    Quote Originally Posted by Zaridar View Post
    I have a NP205 mated to a 4L80E for sale, both fresh rebuilds, PM if interested
    84 K3500 Suburban, 05' 6.0L, forged, balanced, studded, boosted, 4L80E, NP205, D60/FF-14B, 37x12.50's.
    98 K2500 Suburban, currently undergoing 6.0L conversion
    I have a good 4l80e. I just need t case/ adapter
    So it has been a millennium since I last posted.. Had a couple babies, moved, work etc etc etc.... Finally got the T case and adapter... NP 205. $225 craigslist special
    Hope the pic works
    Any thoughts on this T case? It's got u joint yoke rear. My previous 205 has slip yoke. As does my rear shaft... Should/ can I just swap tail shafts on t cases and use current driveshaft or look for slip yoke eliminator type dtiveshaft?
    Anyone use a signal generator adapter for speedometer? Speartech says it's a 4K pulse I was looking at the Dakota Digital one but it says 8k...
    http://www.dakotadigital.com/index.c...916/prd916.htm
