Hearing mixed reviews on this set up. I heard it flow good but the larger valve may have clearance issues. Can anyone verify this?
4 inch bore is minimum size for L92's to fit. lq9 has a 4"+ bore. lots of ppl run em.
is the lq4 the same?
[QUOTE=skeet;390770]verified no issues if its setup properly ;)
Set up properly...say if I had them milled .030 and a cam like a torquer v3 with say a ls6 head gasket, I think it's a 5 layer someone said, would this be properly done?
if im correct the L92 heads intake side flows much more than the exhaust side so the cam must have bais to the exaust side with a longer exhaust duration.
dont really have to have the l92/ls3 gaskets any 6.0 head gasket will work ;)
the cam mentioned isnt gonna cut for best results for a 6.0 ls3 top end setup.. what goals are you aiming for with this setup!!
Decided to go with a custom grind but specs are still being researched. Goals for this is 425-450
