5.3 oil pan cracks
I am in the process of removing the sludge from my 5.3 2004 Tahoe. My castech heads went bad around 130K. I pulled my oil pan and noticed there are several hairline cracks on the inside. The outside looks good and I wasn't leaking oil before I pulled it. Any advise as to whether I should replace it? Is this normal?
see pic:
- You may not post replies
- You may not edit your posts
