Installed the transgo shift kit in my 4l80e and I'm not sure if its working right. I have done shift kits before and they would shift firm and hard. this shift kit installed in the 4l80e shifts normal. almost to soft. when I put it in drive I dosen't even feel like its going into drive. Its dosent slip into drive or anything. I just give it gas and it goes. It shifts into all the gears, there is no hesitation or slip. The trans temp sensor is inline and reads 210 after driving around normally. I have a tru-cool max trans cooler so I think it should be running cooler than that. I followed the directions to the T. I did the direct clutch spring swap and the drilling in the pump. It just seems like I might be losing pressure somewhere. any ideas???
