thanks for the input guys! Both very knowledgeable guys so I really appreciate it. Im going with the fuel rail setup just like you said George and Im going to go with -8 feed and a boost referenced fp regulator after the driver side fuel rail. Then -6 return. Few more questions, I have a left over fuel pump from a chevelle 502 fuel injection build my dad and I did a few years back. This thing is huge and if I can use it, I would like to since I have it already. I read some where it can support 700-800 rwhp. Here is a link to it.
http://www.summitracing.com/parts/ACC-75709/ according to the specs on summits site, it flows 110gph, I did the math and its right at 416lph. So can I run this pump? If so, how do I go about getting my -8 feel line into the tank and down to where it needs to be? I was thinking I could remove the stock pump and run some copper tubing from where the stock pickup is and run it out the top of the bucket somehow.
