Results 1 to 7 of 7
Thread: How to remove pillar panel
    Mar 2006
    OK guys just as it says, does this thing just snap out, where do i pry on it...I am going to mount my tach above me in the corner and route my wires behind it, so please help me with how to remove it....thanks in advance
    Jarrod
    Nov 2005
    yeah it should be held in their with door panel like clips..i havent taken mine off but thats what i always thought they were held on by..so wait until someone else replys..but if its door panel type clips then youll need a couple new ones when you go to put it back on...cool monte by the way
    Project: 91' short wide:
    GMC front end update with billet grille and all clears, 17x8 & 17x11 Torq Thrust II's
    5/7 drop, almost totally shaved and 93 Deville tails
    Future Plans: 2001 LQ4 6.0L & a T-56
    DD: 98' 5 speed GT : Dumped Exhaust, CAI
    Aug 2005
    St. Anthony, Indiana
    grab it the top and pull it out. there is 1 metal clip towards the top that holds it. where it meets the dash it fits in a groove in the dash.
    Mar 2006
    <div class='quotetop'>QUOTE(foggy &#064; Feb 15 2007, 07&#58;49 PM) [snapback]83389[/snapback]</div>
    thanks foggy, do I need to pull toward the other side or toward me.....I assume you meant there is one clip in the top and in in the bottom, is this correct?
    and thanks C1500 for the compliment on the monte...I love that car, just havent got around to painting it.
    By the way what the hell is up with my sig pictures, they just keep changing at random, am i just an idiot or do i need to reload them on photobucket like everyday???
    Aug 2005
    just one clip at the top. the bottom just sits in a groove.
    Aug 2006
    LAKECHARLES, Louisiana
    <div class='quotetop'>QUOTE(foggy &#064; Feb 15 2007, 07&#58;07 PM) [snapback]83398[/snapback]</div>
    Yep just one clip. Had to remove mine to mount my gauges and pillar pod.
    2000 Chevrolet Silverado, 4.8L, K&N polished intake, 4.10 gears, 20x9 KMC SS on front, 22x10 on rear, Dual style pillar gauges, steel cowl hood, 2" rear drop shackles, true duals w/IMCO extreme mufflers w/dumps at rear end, SLP headers. Cam and nelson tune soon to come!!!!!
    Mar 2006
    Thanks 4 all your alls help.....much appreciation&#33;
    jarrod
