Page 9 of 9 FirstFirst ... 7 8 9
Results 81 to 90 of 90
Thread: Hrv- sierra 95 rcsb
  1. #81
    Oct 2010
    Southern California
    Quote Originally Posted by kewljay223 View Post
    Well normal operating temp is around 200 degrees. What are u considering "extremly hot"? Id say anything 200 degrees is not gonna be fun to touch. Lol
    Its ok. The top one is hot, and the bottom is cooler. should be fine.
  2. #82
    Oct 2010
    Southern California
    Does anybody know the part number for the anti-wave action plate that goes in the obs fuel tanks? Got wave action on the needle. I'm sure its not exactly called like that, but I hope you understand.
  3. #83
    Mar 2013
    Long Beach California
    Didnt know such a thing existed for fuel tanks... thats cool. i have that same thing going on on my needle too. i might want to look into it.
    idk what its called either but if its like whats in the oil pans... maybe a "windage tray".... haha thats my guess...
    CALI LEGAL ENGINE SWAP!
  4. #84
    May 2007
    Medford, OR
    Its called a baffle. But I am not aware of it being available separately.
  5. #85
    Oct 2010
    Southern California
    Got one problem. On my airfilter housing box, theres a vehicle emissions info label there. The problem is that it shows its for an 2004, my engine and ecu are 2003. That may cause a problem with the ref, maybe. Not sure. Anyway, the dealer doesn't sell that label, got to buy the whole damn thing (airfilter box). Is there someplace to buy this label?
  6. #86
    Oct 2010
    Southern California
    Got the label I needed. There was confusion on my part at the dealer. Anyway, hooked a scan tool to the ecu port, and I don't have any alarm codes. The only problem is now that 2 monitoring systems need to run their course. They are the oxygen sensor and the evap. They both blink on my scanner indicating that they have to run their course. Read in the manual what I need to do. Its a process of starting the engine when its cold, letting it idle, then drive it at 45 till it gets to temp. Then let it sit for an hour then check. The thing is, I driven the truck a few times at those speeds, so I don't know. Do I got to drive it some more to go through these tests? ? I did use heater hose and small radiator clamps to secure the hose to the evap solenoid and charcoal canister. Would it really matter if I didn't use a special quick connect to the charcoal canister??
  7. #87
    Oct 2010
    Southern California
    I'm still driving the truck with the 2 monitoring systems " not ready or yes". I'll keep going, and going,......
  8. #88
    Oct 2010
    Southern California
    Got a question. When I'm driving the truck at 65mph., the rpm is 2300. The rear axle ratio is a stock 3.42. The tires are 255/55R17. Does the rpm sound right on for this or is it too
    high?
  9. #89
    May 2007
    Medford, OR
    Is your speedo correct?
  10. #90
    Mar 2013
    yeah since you have bigger rims on there it may have changed the accuracy of your speedo depending how much taller your tire is but i wouldnt think much since they are not all that much bigger than stock. the rpm sounds about right tho. RPM is just what it is depending on gears and tires. your speedo is what is going to drastically change. if your still using your drac box for speedo signal, then read my post about how to adjust it in my thread http://www.ls1truck.com/forums/showt...693#post513693 if your using the pcm to control it, then you just need to have it tuned for your setup.
    here is a pic of my dash on my scanner (which you now have also) while i was on the freeway. Its blurry but if you look close it says im going about 64mp and my rpm is at 2240. but i have different wheel/tire gears than you. but since you have the same software as i, just go for a drive and watch it and compare it to your speedo and tach if you have one. the software is dead on. i compared it to gps to verify.
