Page 9 of 17 FirstFirst ... 7 8 9 10 11 ... LastLast
Results 81 to 90 of 166
Thread: Billet Servo Installation
  1. #81
    Bloomingdale Illinois
    Here is a picture of the two sonnax pieces together. In this picture I have added a trans go washer (gold) but it is not required. Make sure your assembly looks like this. Vince B
  2. #82
    Thats what it looked like...i'm getting ready to attempt it again
  3. #83
    I'm working on the servos again and i can get the it in and when i put pressure on it i can get it in far enough to get the spring clip in but then i wont have the pin travel i need. With this said obvioulsly need to grind the pin so I take it if I take .125 of I'll have the clearance I need...right?
  4. #84
    sounds about right if you have zero travel with it as-is.
  5. #85
    Sweet...back at it then!
  6. #86
    Must be when I first tried the spring must have fallen off before i got it in...took off about .125 off the pin length and it went together! Raining out now so i'll wait till the morning and go try it out
  7. #87
    Jun 2009
    Washington DC
    good luck dude, hope it works out
  8. #88
    I would NEVER grind or otherwise modify the pin length on a trans that worked properly before servo PISTON replacement. That makes no sense. It does mean something was not assembled correctly.
  9. #89
    The pin in the kit is longer than the stock pin to make up for worn bands...it tells u that you might have to alter pin length to get the travel you need
  10. #90
    Then reuse the original pin. If the band is worn it needs replaced. The friction material on the band is 1/16" or so thick so when it's toast, it's toast.
