Page 9 of 11 FirstFirst ... 7 8 9 10 11 LastLast
Results 81 to 90 of 101
Thread: Help!!backfire problem
  1. #81
    Ok i dont know what else it could be ....
    has new plugs,new wires,new fuel pump assembly,found that broken tensioner ,replaced with ls2 tensioner and new chain...tune is dead on....and this thing still backfires from a dig at wot...even at 30 40 roll sometimes....i give up...maybe i mest up something while it was running super lean on the bad fuel pump?
    next thing i will try is a 3600 stall...maybe the cam doesnt like the low rpm..cause dont get me wrong it runs good other than the annoying backfire u can hear a block away haha
    i may even put the l92 truck intake back on if nothing else....
  2. #82
    San Marcos Texas
    Check all the rocker arms make sure they are tightened down and moving correctly.
  3. #83
    bad grind on cam, might wanna check it
    Simple: 408 on steroids!
    single digits coming soon!
  4. #84
    Quote Originally Posted by GMCwantsLS1 View Post
    i did that too,checked all the pushrods as well
    Quote Originally Posted by skeet View Post
    yikes
  5. #85
    San Antonio, TX
    still might be what i was explaining when you were here.
    i believe it still popped when in park, correct? the converter will really make that truck get out of the hole, but might not help the pop.
  6. #86
    Round Rock, TX
    Do the simple stuff..compression test and leakdown. See if there is a valve issue..
  7. #87
    San Antonio, TX
    my truck backfired when i had a leaky valve. it was under 3psi, but still a good place to start.
  8. #88
    San Marcos Texas
    A leak down test as well as a compression test should tell the tale. Does it still have converters? Is the backfire out the exhaust or the intake?
  9. #89
    Dec 2009
    houston tx
    told u it was the timing chain tensioner!!!!!
  10. #90
    yea it still backfires in park...i even moved the maf right in front of the tb....the back fire is out the intake ...can hear it clear out the cold air.loud .....
    if any of u can break me down a compression test procedure for the ls1s..ill do it right now and get some readings...appreciate all of yall tips and info..
