Page 8 of 8 FirstFirst ... 6 7 8
Results 71 to 74 of 74
Thread: 1995 C2500 ls1 swap
  1. #71
    Dec 2008
    South Carolina
    I hooked the white tach wire from the new PCM to the white wire at the back of my factory gauge cluster....the tach operates now, but is no where near being accurate. At 4000rpm it's only reading around 1800rpm. I'm thinkin I may need to try the resistor trick????
    2008 GMC Sierra SLE....370ci LY6 with some goodies SOLD
    1995 C2500- LS1 swap with a mp112
    build thread- http://www.ls1truck.com/forums/lsx-t...-ls1-swap.html
  2. #72
    Aug 2012
    Portland, OR
    Quote Originally Posted by chvy=power View Post
    Mine did the exact same thing! It reads half of the actual RPM. If the tach moves, then everything should be wired correctly. The tune needs to be changed to a V8 signal instead of a 4 cylinder signal. Your tuner should be able to fix that easily. Of course, you can try the resistor and see if it helps before trying the tune, but I think the resistor trick was for when the gauge didn't work. Regardless it's easy enough to give it a shot first especially if you have to mail your PCM in to be tuned.
  3. #73
    Dec 2008
    South Carolina
    Na I have hp tuners so adjusting the tach signal won't be a problem....I'll do some research and see what it needs to be set at in the tune
  4. #74
    Videos man! We need more videos!
    Ethan
    First & only 4th gen Ram 4x4 in the 12's NA 12.747 @ 104.07 (1.663 60')
    2012 Black SC 4x4 1500 Hemi ARH longtubes, Vararam intake, Circle-D 3000, Meziere E-water pump
    Moe's 87mm throttle body, efan, 2010 frontend swap/4.56 gears, Greene Racing tune, E-power steering pump
