none!!! i hit it with some degreaser & then hot water pressure washed it. pressure washer took off most the surface rust & then you Por-15 over the rest of the rust.
WOW. If I ever have mine that far apart I will definitely be doing the same thing.
T-RAV99 GMC | 5.3 | Skinny White Guy Tuned
I just dug through a factory 5.3 wiring harness and got the pig tail for the oil pressure sending unit.
Pigtail for sending unit has grey, tan, and black wires. The stock wiring on my truck has grey, tan, and orangish wires...I'm going to assume that I'll be splicing the orangish wire into the black one?
95 C1500 LM7, built 4L60e, Circle D 3200, LT's, Nelson tune, open differential, 3.42, and LS1 e-fans. Tractionless
I'll be hooking up the trans tomorrow and if time allows headers also.
Hell yeah. Glad to see it coming along man.
Thanks man!
My sig is out of date now
progress progress progress! looking good man!
Keep it up man it looks great.
Hurry every chance you get!!
