Page 7 of 14 FirstFirst ... 5 6 7 8 9 ... LastLast
Results 61 to 70 of 138
Thread: How to 4L60E to 4L80E trans swap
  1. #61
    Aug 2009
    Has anyone done the 80e swap on a 2007+ non-classic truck?
  2. #62
    I will be trying one before too long. I'll be sure to document it if I'm successful.
  3. #63
    ryan_prettyman Guest
    Well I called the deallership on the part numbers to get prices the lower bell housing part # is no good the good part# is 15765623!
  4. #64
    Nov 2006
    Mesquite, TX
    we did the swap on mine this past weekend and also found a flexplate that doesnt require a spacer...i left the box at Jon's with the PN though....i will call him in a bit to find out what the number was
  5. #65
    Thumbs up
    Hey guys I am putting all the parts together for the trans swap and here is a parts list from fastenal for the longer lines needed for swap we use the same fittings on the aircrafts guaranteed not to leak and for high vibration all you will need is some 3/8's tubing for ext.
    442056-131280 2 3/8"Tube OD ZincPlated 12L14 Steel For-Seal Union 1 $2.91 $5.82
    420117-131280 4 3/8"Tube OD 0.38"L 12L14 C/S ERMETO Flareless Sleeve 1 $1.07 $4.28
    420133-131280 2 3/8"Tube OD 0.75"L,7500psi C/S,7000 Series Flareless Nut 1 $1.14 $2.28
    420330-131280 1 3/8"TubeODx1/4"MPT 7500psi C/S 90Deg Flareless ERMETO Elbow 1 $9.29 $9.29
    Freight cost (UPS Ground Service) $7.87
    Sales tax $2.24
  6. #66
    Here is some pics of my cross member before I sandblast it and paint it!
    [IMG] [/IMG]
  7. #67
    Augusta, Ks
    What year is that crossmember out of? Mine looks nothing like that
    2004 Buell XB12s
  8. #68
    Well I got it from the salvage yard it is the same one that is in my 06 crew cab 1/2 ton I just assumed that all 03 and on up 1/2 ton 2wd were the same I know the earlier 99 and up were different!
  9. #69
    Oct 2008
    great write up
  10. #70
    Jan 2010
    well i just blew my 60e for the 7th time in my 96 gmc. a buddy told me he had a 80e i could have that's in good condition. so since everybody seems to be doing this swap in newer models what would be needed to do it for my 96? the 80e's from a 97 1 ton with a 454 but my buddy sold the motor and harness
