Page 6 of 15 FirstFirst ... 4 5 6 7 8 ... LastLast
Results 51 to 60 of 146
Thread: OBS to LSx conversion
  1. #51
    Yes, you can use your old radiator/trans cooler.
  2. #52
    Jan 2007
    Stafford, VA
    A good read if you want to do a stroker... http://www.gmhightechperformance.com/tech/...s1_engine_build
    The new URL for this is:
    http://www.gmhightechperformance.com...ild/index.html
    Took me a few minutes to find. GM High Tech has a LOT of articles.
    - Paul J.
    2006 Silverado LT3 L33 Z71 - Mods: K&N Air Filter; Taylor Wires
    2008 Azera Limited - Mods: (Yah, wife's car ... not happening)
    (SOLD) 1994 Camaro Z28 - Mods: (Too many to mention)
    (SOLD) 2004 Suburban 5.3L Z71 - Mods: Flex-a-Lite 292 Monster Fan
    (SOLD) 2000 Silverado 5.3L Z71 - Mods: (NTIKO)
    (SOLD) 1991 Suburban 350 2WD - Mods: (NTIKO)
  3. #53
    Quote Originally Posted by Paulster2 View Post
    What search criteria did you use?
    1979 C-10 Big 10 LSx powered BUSTED REAR END
    1994 K1500 05 L33/60E swapped
    2005 Yukon 4x4 factory 4.10's
  4. #54
    Jan 2007
    Stafford, VA
    Quote Originally Posted by bowtieguy79 View Post
    Not sure what you mean, but when you do a search on their site for LS1 ... you get about a thousand returns. Looks as though they have moved all of their LSx articles into a subdirectory called lsx_engine, then I found the article which started "0608..." (which relates to June '08, or the article month) and found it from there. I tried using the name of the file (which was available from the old link) ... but then again ... why am I trying to explain this? Purpose of posting was to give a current link so people could find the information. Hope it helps.
    - Paul J.
  5. #55
    Awesome thread
    1990 RCSB|T56|14bolt|4.88|TrueTrac|Cam|.060 over|ported_polished|Headers|3" duals, "H"|E-fan|Ult TBI|2"/2" drop|DIY tune|6lug swap|16x8 AR-Atlas
    Slowly gathering parts for LQ4 swap
  6. #56
    Feb 2009
    baytown, tx
    I'm a little lost on the ABS when converting over to the LS motor. I seen on here where you have to run both PCM so the ABS still works? I'm fixing to to do the swap on my 96 truck in a month so I'm trying to get all the info before hand.. My plan is to get a wiring harness from Nelson's..
    Also I'm dropping in a 2002 6.0 what fuel line fittings do I need? But I'm not going to use the stock truck intake was thinking of going with one of the car intakes just not sure the one I'm going to use!!
    Is there anyone around Houston on here that's done the swap to the 96-99 truck that I can get with if I have any ??'s
  7. #57
    Jan 2011
    Great info. Who sells the ac adaptor or relocation bracket to use the 95 compressor on a ls engine?
  8. #58
    Agreed. THis is a very helpful thread. Shoudl be read by all before they try their first swap!
    and I call myself a mechanic...
  9. #59
    Apr 2011
    Just read the whole thread.
    Lots of good info in here After reading this, the wiring is the only real thing that is puzzling.
    I do have one specific question though, related to a LY2 swap into my '92 full size Blazer.
    What do I have to do related to the stock trans in my '92? Its a 700R4 with the only electronic piece being the torque converter lock up. I have read that I can wire the trans so the torque converter locks up automatically, but that it only does so in OD, where mine locks up in 2nd, 3rd, and 4th (I think) and want to keep that functionality. Can this get wired to the factory engine computer? Does it need to be wired via a separate torque converter lockup control system?
  10. #60
    seriously, the 700r4 will not live even with a 4.8l unless its beefed up. www.hotrodlane.cc has adapters to make the 700 work but its gonna need help.
