Page 6 of 12 FirstFirst ... 4 5 6 7 8 ... LastLast
Results 51 to 60 of 116
Thread: budget ls2 s10 conversion
  1. #51
    Jan 2012
    I've always wanted to do this. looks awesome!
  2. #52
    Jan 2005
    Humble/Houston TX
    little progress today.
    old mod list: H/C/I/N/E/G 408
  3. #53
    Sep 2012
    It's hard to tell, do you have the steering shaft hooked up and how well does it clear? Where are you planning to mount the coil packs? Looks good sitting in there!
  4. #54
    Jan 2005
    Humble/Houston TX
    the cab is lifted/tilted back about 8" so the steering shaft is currently disconnected. notice the wood blocks between the frame and cab. I hope to put the coil packs in the OEM location. we will see what the clearance looks like once i install the trans and drop the cab back down.
  5. #55
    very nice project. I dont like the way those headers have two tubes going outside the frame rails, as tire clearance get to be an issue, but otherwise should be a sweet little truck.
    Im in the finishing stages of a 96 S10 Ext cab with a 408 T56 swap, stock 8.5 rear with a true track and 4:56 gears. Nelsons did the tune, but im currently having some issues with the LTFT being pegged at 25%.
  6. #56
    Montgomery, AL
    Did you get the rear axles redrilled to be 5 on 4.75 or will you just leave them 5 on 4.5?
  7. #57
    Jan 2005
    Humble/Houston TX
    Quote Originally Posted by SyTy Speed Shop View Post
    i didnt have much choice on the headers. i refuse to get tfs heads then choke them off with a 1 3/4 header. i will be running skinnies up front anyways so steering shouldnt be an issue. also decided to go full manual steering since i will be running skinnies.
    Quote Originally Posted by Skyhighsami View Post
    i got another short side axle last weekend so i can cut down the drivers side 3". i may have the axles redrilled at that time since it will be apart. the ford lug pattern doesnt bother me though so who knows...
  8. #58
    Your thread really makes me want to do a v8 swap in my 01 s10, keep up the great work!
  9. #59
    Jan 2005
    Humble/Houston TX
    got all of the front accessories modified, painted and installed over the weekend. also got the transmission bolted up but i'm not thrilled about how the trans crossmember fits. i am sending some pictures to hedman today to show the fitment of the trans crossmember. maybe they had a bad batch of crossmembers? i had to use a wratchet strap to pull the trans 1/2" over to get it to bolt to the trans mount. then it gives the drivers collector a mile of clearance but the passenger side is tight. it also seems like it is leaning to the passenger side. who knows. they may say it's normal but after how great thier motor mounts fit i doubt it.
    drivers collector clearance
    passenger collector
  10. #60
    Doesn't exactly look like that crossmember went through the strictest quality control
