Page 6 of 7 FirstFirst ... 4 5 6 7 LastLast
Results 51 to 60 of 73
Thread: PCM or not wired right
    The VIN is stored in the PCM. Don't let him change or reload the tune. Just verify that the VATS function has been turned off.
    There's really no way I know to bench test a PCM with exception of the aftermarket tuners. I think what was said earlier was the MAF is one of the only 12V sensors as most are 5V. The CMP and CKP are 12V also.
    Here is where we are at now, its actually where we began.
    the yellow wire has been reconnected to its other half. he then took the purple solenoid wire (from the old harness) and ran it to the starter, turn the key, nothing happens. which is odd, as his truck was running fine with the old engine installed, so this solenoid wire should activate the starter fine but it doesnt.
    just for the hell of it, he tested the solenoid wire on the new pcm with his multimeter, to see if he would get 12v with the key in start position...nothing.
    otherwise, he is getting power at the PCM where it should be and the fuel pump relay on the new harness is clicking, as it should.
    this is with the new harness connected to the Neutral safety switch (NSW). for chits and giggles, we even attached the old NSW to the new harness connection, then we connected the old and new NSW to the old harness NSW connection...nothing.
    LSX conversions, so easy a caveman can do it.
    Kentucky
    after talking with Jon this morning there going to get another pcm loaded and sent out.
    1996 GMC extended cab, 2003 5.3/auto
    May 2004
    Good luck, It's hard to diagnose an electrical issue over the net, you really need someone looking at it with you. I doubt this is a BCM issue, it's more than likely wiring or PCM/tuning related.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    I forgot the vehicle is older than the harness and engine. The BCM doesn't factor here AS LONG AS THE TUNE HAS THE SECURITY TURNED OFF.
    I keep looking at description and operation for the donor harness/powertrain forgetting the vehicles are often different.
    I still surmise it's a security issue which would still be PCM related.
    May 2004
    I keep doing the same thing so don't feel bad. This kinda stuff happens when you combine different year models.
    97 GMC, 2002 LS6.
    Shouldnt be a wiring issue, Id be happy if it was though, then this would be over and done with.
    To take one more variable out of the equation, he asked them to turn the neutral safety switch off within the computer. Im fairly confident everything else is wired as suggested, and no stock wires were modified....cross our fingers and hope fer the best I reckon.
    Programmer man said you cant turn the neutral safety switch off inside the pcm via tuning.
    What do you do to bypass it, just not connect it?
    Oct 2003
    Quote Originally Posted by LSXmyford View Post
    Correct.
