Page 5 of 7 FirstFirst ... 3 4 5 6 7 LastLast
Results 41 to 50 of 65
Thread: My 5.3L into an 85 GMC swb 2wd swap
  1. #41
    san antonio,tx
    love the engine paint scheme. nice. i did mine all black with red. but im digging th metal and red color.
    Powered by a 355sbc and 150shot but soon a newer v8 in 2008........
    http://i26.photobucket.com/albums/c1...DSC02135-1.jpg
  2. #42
    Aug 2009
    Thank you!
  3. #43
    Jul 2009
    Northern Colorado
    Quote Originally Posted by vandejr View Post
    Thanks! I'm kind of bummed that you can't see more of the red now that it's installed, but the whole combo looks really good in there.
    Quote Originally Posted by jerseymike68 View Post
    Thank you!
    For what?
    85 GMC Sierra Classic SWB
    5.3L / 4L60E / 3.42
  4. #44
    Aug 2009
    so you have 87 tanks for the baffles im thinking??
    what pump are you using and what did you do about fuel lines im getting a TBI Sending unit im stuck on the pump and what to run for lines?? any ideas???
  5. #45
    Jul 2009
    Northern Colorado
    Quote Originally Posted by aussie View Post
    Yeah, I wanted the bowl in the tank. I had been running the stock 85 tanks (no bowl) with the TBI and it would die if I stopped to quickly with anything less than 1/4 tank of fuel.
    I'm using ACDelco EP-381 pumps (FE0114 - Electric Fuel Pump $69 each), they've are giving me right at 58 psi.
    I ordered FI rated 5/16" hose for the return lines, and Summit's -6 hose for the pressure side. FI rated clamps on all the tank and valve connections, and Summit's Snap-Tite AN fittings on the Vette filter/regulator and fuel rail.
    It's been working perfect.
    5.3L / 4L60E / 3.42
  6. #46
    Aug 2009
    ok so will i need to use vette filter /reg on mine i cant see a reg on the fuel rail mine is a 2000 ? and what is summit-6 hose is this hi pressure? thx for the help
  7. #47
    Jul 2009
    Northern Colorado
    Does your fuel rail have one or two lines on it? It probably has two if it's a 2000 model. If it has two, you won't need the filter/reg, but you will if it only has one.
    This is the hose:
    Summit SUM-220785 - Summit Racing® Twist-Tite Hose - Overview - SummitRacing.com
    5.3L / 4L60E / 3.42
  8. #48
    Aug 2009
    it has 2 lines so i will get some -6AN line from the sending unit to a filter (any suggestions on the filter) then from the filter to the engine -6AN line 5/16 EFI hi pressure line for the return!! could i use this
    NOS 15430 NOS Stainless Steel Braided Hose
  9. #49
    Jul 2009
    Northern Colorado
    You could, but that is a retarded amount of money for braided line! Summit sells -6 AN stainless braided hose, same length (6') for $26.95.
    5.3L / 4L60E / 3.42
  10. #50
    Jul 2009
    Northern Colorado
    I guess I should update.....
    Took the truck on it's first drive this Saturday, and it runs awesome! Even with the 2.73 rear end in it, it still runs fantastic! I can't wait to get the 3.42's in there.
    The first tank gave me 252 miles to just barely under 1/4 tank, so I think pushing 25 mpg should be easy. I was hard on this tank, hard on the gas pedal, and not slow on the highway! So once I get the better gearing in it and ease off the go-fast pedal, it should start producing some great mpg numbers.
    5.3L / 4L60E / 3.42
