ive been told to replace my o2's 2 times (lean 02 code) and i havent once done it. it took me a while to find the problem but what it was is i had a leak in my exhaust manifold gasket off cylinder 7 so it was pulling fresh air into the exhaust before the o2 sensor making it read lean and the truck started dumping in alot of fuel and making it smell like it was running rich so if u havent do a quick check for a leak some where, if ur trucks loud u might not have hear it
There are a lot of technical issues with the post and I hope NITROUS comes along and explains the stuff I miss but....
First, are you talking long term FT or short? If short, forget it. If long, forget about +3 (or -3) fuel trim. Some of these things run perfectly at or above +/-10. It's when you get past the mid teens either way that there could be an issue. The PCM has the ability to adjust so the +/-10 is nothing.
-20 is an issue if LTFT is what you're talking about. If you have cats it is pretty likely the LH (driver side) cat is dying. Then again, since LT and ST fuel trims are averaged per bank, you could have one almost inoperable injector causing a lean condition that is being covered up by enrichment, a leaking fuel pressure regulator (depending on the year) a fualty B1O2S1...anything that is specific to Bank1.
The EVAP purge solenoid never vents...even on a malfunctioning system. You may have the purge solenoid and the vent solenoid confused. The PC is on the intake manifold, the VS is underneath near the fuel tank. IF the PS was stuck open you'd have a huge vacuum leak and very lean FT's on both banks. If the PS was stuck closed you'd only have an SES light. If the VS was stuck open you'd only have a SES light. If the VS was stuck closed you'd have an SES light, fuel smell, and hard to fill tank situation.
The fact the trims change at higher but nearly steady RPM means something but the data you've supplied is a little confusing. What scanner/system are you using to retrieve DTC's and trims? -20 aught to set a DTC (+/-17% in many cases and +/-25% is max)....
I use the genesis scan tool.. and it is the vent solenoid, sorry typo. i did a crankshaft relearn, and all the rich codes went away for a little while, but then they came back
5.3L, 4L60E, True Dual Exhaust, 40 Series Flowmasters, K&N Cold Air Intake, Nelson Performance PCM, 93 Octane, 0% TM, Ram Air Hood, 35" Pro Comp X-Terrain's, 18" Mazzi Sphinx Wheels. 3000 stall Yank, TCI clutches, Trans-go Shift Kit. Soon To Come:
4.56's, Cam, PLT's
and yes i am talking about ltft
4.56's, Cam, PLT's
4.56's, Cam, PLT's
Bank 1 Oxygen Sensor 1.
Beg, borrow, or steal (not that option please) a Kent-Moore exhaust backpressure gauge and test both converters.
okay. i think im gonna buy some new o2 sensors tommorrow.
4.56's, Cam, PLT's
what psi should the backpressure read?
4.56's, Cam, PLT's
Less than 1.5" of Hg in front of the converters at idle and less than 2" at 2500 RPM.
