Page 40 of 44 FirstFirst ... 30 38 39 40 41 42 ... LastLast
Results 391 to 400 of 436
Thread: my first ls swap 1996 2 door Tahoe 4wd 385 Stroker to LQ4 cam headers **pics**
  1. #391
    Jun 2009
    Caledonia, MI
    Man what a pain! Hate problems like that when its something so simple.
  2. #392
    Sep 2011
    Atlanta Ga
    Quote Originally Posted by HPICamaroSS View Post
    yea man...so i got it all put back together and she drives GREAT!!!! shifts nice and smooth...tons of power! but now i have another issue....the pcm isnt turning on the fuel pump. right now i hav it hooked up to ignition. but she drives great
  3. #393
    Glad to hear you got it fixed. A little diagnostics will do you good.
    Green PCM connector Pin 9 is a dark green wire with a white stripe, it triggers the relay for the fuel pump. It supplies power to the relay.
  4. #394
    Sep 2011
    Atlanta Ga
    yea for some reason it was in green pin 5 and worked til now lol. its in pin 9 and theres no power. i cut it and put the test light to it and theres no power at all. no codes are coming up either.
  5. #395
    Sep 2011
    Atlanta Ga
  6. #396
    Don't blow it up before you get to Georgia!
  7. #397
    Sep 2011
    Atlanta Ga
    lol..ill try my best! any idea why the pcm wouldnt activate the fuel pump?
  8. #398
    May 2010
    Galveston, Tx
    "They speed limit over here is 35...but who cares"
    95 C1500 LM7, built 4L60e, Circle D 3200, LT's, Nelson tune, open differential, 3.42, and LS1 e-fans. Tractionless
  9. #399
    Sep 2011
    Atlanta Ga
    Quote Originally Posted by silverado_lover View Post
    i gotta find a back road to have some fun on. i went to cvs later on and got pulled over. luckily for me the cop was cool. he asked me why i was driving so fast and i told hm i just put a new engine in. explained to him a little what i did and he just happens to own a 95 blazer lol. he checked out under the hood and everything. lol chevy runs deep!
  10. #400
    Bad pcm? Checking wrong pin output? It only supplies power while the engine is running and for two seconds when you first turn the key on.
