i removed the wheel well from the fender. i was planning on doing the outer wheel well in flat black and do the inner in a gloss black to match the firewall and frame
You don't need to do all of this to get 350whp out of a 5.3L LM7 engine. Check this thread here. While 322 is not quite 350, it wouldn't take much more to get you to 350. This is a very street/wallet friendly build.
Another thing with the above statement is: there is a lot more to selecting valve springs than just "get springs with just enough tention to close the valve", as there is such a thing as harmonics. I agree you don't want to get a spring with so much pressure it's overkill, but throwing a general statement out there like that will bring bad results.
- Paul J.
2006 Silverado LT3 L33 Z71 - Mods: K&N Air Filter; Taylor Wires
2008 Azera Limited - Mods: (Yah, wife's car ... not happening)
(SOLD) 1994 Camaro Z28 - Mods: (Too many to mention)
(SOLD) 2004 Suburban 5.3L Z71 - Mods: Flex-a-Lite 292 Monster Fan
(SOLD) 2000 Silverado 5.3L Z71 - Mods: (NTIKO)
(SOLD) 1991 Suburban 350 2WD - Mods: (NTIKO)
what do you suggest? so far im ordering the schenfeild lt headers. i was talking with someone else as far as the intake because i need to convert from dbw to dbc. so i was planning on changing the intake to a car intake. with the lm7 heads what intake would work well?
No actually I'm in Rancho Cucamonga. I didn't really run into any major problems just some wiring headaches. I would suggest a pre made harness from nelson because it really would have helped me. I cut up the stock harness and it is not as clean as I would like to be. For the 6.0 i will have a pre-made harness with just the essentials.
SOLD:1992 ECSB Silverado lm7 5.3 Swap, TR220 cam, Circle D 3200stall, CBM street tune, Schoenfeld LT's, LS1 efans, transgo hd-2 60e, custom CAI, Autometer gauges
Best 1/8 E.T. 8.86 @ 77.8 on 275/60/15 MT ET Streets with 1.92 60 ft.
2000 RCSB 4x4 Lq9 swap...stock except mild 4l65e....for now
oh ok. i found a guy in south gate that said he can do a harness for 450. i might go with that. my original harness was designed for dbw. so is my intake. so im converting to dbc because i dont have the module or the pedal assembly. im still kind of confused on one thing with this swap however. how does my transmission work? ive read so much and the info regarding the transmission during this swap is very vague. i have a 96 2d with 4wd and a 4l60e. all ive found is that i need a spacer and a flat flex plate. i have the original off the engine and i plan on using a yank 300 stall. is there a plug on the ls harness that will power the trans or how does that work? if your ever in the long beach area i could always use a hand! lol
thats what i would do... allthough, powder coating the inners would work alot better, because it will stand up to the elements WAY better.
I don't think Shoenfields fit 4x4s... Sorry.
Your 2005 DBW truck intake is exactly the same as the DBC 99-02 truck intake. You just need the throttle cable bracket to bolt on to it.
