Page 4 of 11 FirstFirst ... 2 3 4 5 6 ... LastLast
Results 31 to 40 of 101
Thread: Help!!backfire problem
  1. #31
    plug pictures first would be my first move
    if you are injesting coolant it will do as your saying, if youre timing chain came loosse you would throw a code. Going WOT with any issue is flat out stupid as it can cause you a permanently hurt motor.
    I would get a damm scanner on that truck and log it before id do anything
    ill remove em tomorrow and get some pics up,as for the coolant wouldnt the reservour level get low,cause it aint.when the light comes back on ill get it scanned at autozone see whats up....till then i have to wait till the 14th to get the Hp tuner on it
  2. #32
    Pittsburgh, PA
    Quote Originally Posted by CHEVROLADE View Post
    it only takes a small amount to cause a misfire/backfire/pop. over time you would see a level drop
    none of us are trying to be smartasses just trying to help you before you hurt the motor
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
  3. #33
    no problem at all will tear it up in the am or wait till the lite comes on then go get it read ...the light has to be on right n order to read a code?
  4. #34
    Arizona/Utah
    The light has to come on but it could turn off doesn't mean its fixed it will still be in the history.
  5. #35
    put the scanner on her a while ago
    threw..
    PO175
    PO174
    PO172
    P2635-low fuel pump performance??
    P060E-fuel pump control module??
    so should i still tear it down and check the tensioner?
  6. #36
    threw..
    PO175
    PO174
    PO172
    Wow. I hope it isn't the fuel control module.
  7. #37
    where is it located,is it the black box under the bed?
  8. #38
    San Antonio, TX
    lean condition back fire. time for a new pump, then just bypass that fpcm.
  9. #39
    damm...wouldve never thought ide need a new pump.
  10. #40
    May 2010
    San Antonio, TX
    yup same problem i had ...i had nelson's put a new pump and it worked perfect after that
    NOW 69 C10: 4-5 DROP,DISC CONVERSION SOON LSX LY6 6 SPEED SWAP,SOON BOOSTED
    THEN07 TAHOE: LY6 SWAP, 4L80 SWAP, YANK 3000,75# INJECTORS,HOLLEY INTAKE,VOLANT CATBACK AND A NP FRONT MOUNT SNAIL WITH A SILVERADO HD FRONT CONVERSION
