Page 4 of 5 FirstFirst ... 2 3 4 5 LastLast
Results 31 to 40 of 41
Thread: 18k miles 2nd 60e messed up
  1. #31
    Dec 2010
    from what i unstand you do not have to change the tcu program to run a4l80e.
    you can run it with the 4l60e program you all ready have .
    you just have toi wire it up right . wich is not hard
    check here http://forum.efilive.com/showthread....nstall-a-4l80e
    donald
  2. #32
    Mar 2008
    My first "Fresh" 65 trans. failed due to a shaft tolerance issue in first few hundred miles. The second failed at about the 1500 mile mark and was due purely to an improper tune. I had a local shop rebuild the unit(3rd time) due to part failure contamination and correct the tune and have been fine since. If you go mail order make sure someone checks your truck computer an avoid the $8500 bucks I have put in mine. FYI, this is a boosted 6.0...
  3. #33
    Dec 2003
    Quote Originally Posted by mechan12 View Post
    donald
    Wrong. You have to do a segment swap for a 4l80e to work.
    2000 RCSB forged ls1, 4l80e, t-76
    10.93@124 1.58 60'
  4. #34
    Dec 2010
    Quote Originally Posted by quicksilverado View Post
    talking to the fellows from efilive they have a gut slow69 i think that has done it with out doing a segment swap So i will have to try it that way slow69 is running his without doing a segment swap
    donald
  5. #35
    the newer pcm will not control an 80e with the 60e tune. NBS pcms have done it successfully a few times. I'm not sure how they handle the gearing difference, though. If the gear ratios in the transmission were adjustable in the tune it may not be such a big issue.
    on the NNBS trucks its a simple TCM swap, move a few wires, add a speedo connector and you're ready to rock and roll. Read my trans swap post for the details on how to do it. NP can send you out a tuned TCM for the 80e swap.
  6. #36
    Aug 2009
    Humble, TX
    i ve had 12 trans pulls since december of '09. and truck as sitting for 6 months. no gotta pull trans again since i broke other planetary set..... i got over 6k in trans so dont feel bad
    * 2002 Chevy Silverado RCSB w/ 4.3 to 5.3 swap
    Installed: McGaughys full 2/4|HD hood/Z71 Airdam|Circle D Built Trans & 3200 stall|34" fans/radiator|True Trac w/ 3.73s|V8 Swap w/ Milled Heads and Comp valvetrain|Custom Grind 22x/23x Cam|Pacesetters LTs & ORY|Magnaflow|Wheatley Tune
    Future Mods: Paint (Sunset Orange Metallic), milled 243s, possibly a 6.0 with either turbo or procharger
    * 2008 GMC CC Texas Edition: stock with CAI
  7. #37
    Birmingham, AL
    you've broke 12 transmissions with a basic 5.3?!?
    01 Silverado
  8. #38
    Quote Originally Posted by DennisG_02Silverado View Post
    you sir need another builder!
    Simple: 408 on steroids!
    single digits coming soon!
  9. #39
    Quote Originally Posted by skeet View Post
    There's a guy wit a baby baby cam here in my hometown that's gone thru 9 since feb 2010... he dawgs the hell outta his tho...
  10. #40
    yea i dawg the hell out of mine too..Ask Allen he knows..im sure the guy that broke 12 does too lmao
