Ok. Got the plug in and plugged it into the 90mm TB loose to make sure it would work. It worked great until I got to full throttle and it shut down and sent a reduced engine power dash light. I had this same problem when I tried to put an 80mm BBK TB on my engine. Would not be able to open all the way before it tripped the reduced engine power shutdown. Thought it was something with their TB setup but now I am thinking otherwise. Has anyone else encountered this problem and is there an easy fix? The last time we had looked in the tune, the TPS was trying to read past 100% which triggered it. Anybody???????
