Page 4 of 18 FirstFirst ... 2 3 4 5 6 14 ... LastLast
Results 31 to 40 of 179
Thread: LM7 383 Build Up
  1. #31
    Quote Originally Posted by blackout View Post
    This truck will be my daily driver and my tow rig thats why I choose the LS6 cam. I want the vehicle to still be somewhat fuel efficient. What kind of cam did you have in mind?
    TR220 or similar. Small stall converter.
  2. #32
    Oct 2009
    Seattle, WA
    So how would I go about finding a TR220 cam?
    2003 GMC K1500 ECSB running an Iron 383 Stroker ......
  3. #33
    Thunder Racing, Comp Cams, or get a custom spec'd one by Pat G.
  4. #34
    Oct 2009
    Seattle, WA
    So you think like a TR220 cam would do the trick? How does one of those compare to the LS6 cam? And would some 28.5# injectors be enough to power this set up with an LS6 cam or a TR220 cam?
  5. #35
    If V can use stock 24#s on his 370 with a monster cam, IDK why you couldn't use em with that baby cam. Might go with the 36's or 42's, depending on how much fuel that 383 needs and your driving routine.
  6. #36
    Oct 2009
    Seattle, WA
    What risk would I run by initially running the truck with the 24# injectors with the walboro 255lph pump? (That is if the 24# injectors aren't enough) the truck will be tuned by a pro after the build is done, its just I will need to at least run the truck to get it to his shop if not drive it for a week or so before I can get it to his shop.
    Or on the other hand, would I run any risk by running the truck untuned with either 28.5# or 36# injectors?
    Sorry I am new to this stuff.
  7. #37
    If you baby it, you'll probably be okay. The only thing you have to worry about is the injectors overworking, ruining, and leaning you out.
  8. #38
    Oct 2009
    Seattle, WA
    So If I went with some 36# injectors and they ended up being bigger than my set -up needed, what risk would I run?
  9. #39
    Not a thing! You don't risk anything running oversized injectors.
  10. #40
    Oct 2009
    Seattle, WA
    So even if my motor didn't need as much fuel as the 36# injectors can deliver my tuner can make them deliver less fuel? or how does that work?
