quotes are from gmfullsize.com
thanks guys!
thanks guys!
1996 - BIG BLACK: 5.0 | cognito 10+3 | 22/37 toyo | 14B/4:56 w discs | built 4l60e | corbeau
1999 - OBS SS RICER: 6.0 lq4 | autometer | jdm! | whipple | FLT billet 4l65 | yank | truetrac
1954 - OLD RED: Chevy 210 - 3 speed | 235 inline 6
VIDEO
YouTube - 10 feet of rubber half throttle
if you go to youtube you can see the HD version (better sound/video) but thats just a half throttle blip in first and it left about 10' of rubber you can see the before and afters of the street if you skip the video around. the flyby is at about :55
nice build man
MY GARAGE - http://www.ls1truck.com/forums/my-ga...ns-garage.html
2004 GMC Sierra - RCSB
GREAT looking truck!!
BTW whats your little helper holding in the first picture she is on?
06' Silverado RCSB 5.3L 4wd..
HID's Hi, Lows & Fogs
added oil to the blower its a lil better im not exactly sure if it is a problem or not
switched to the ngk tr6 plugs - motor got a bit more lively i had some autolites in there before just threw em in to get it running
wired up my gauges and got the dvd player going (needed reset). the wideband is saying im almost perfect, runs like .5 lean on decel in any gear other than 4. on accel or constant mid-high rpm its a perfect 14.7
now that ive got everything set up pretty nice ive given it a couple of wot moments and damn im not sure what to do with a truck this fast.
i still dont have the speedo or tach running (or fuel gauge - i think the alarm or VATS is disabling the obs ecm) but its damn fast too damn fast damn damn but if you go easy it will drive like a peppy car.
its a hookah - thanks man
A/F ratio is at about 12-13 under boost, probably needs to be adjusted but i barely spend any time at boost
im definitely considering a serious alarm and remote start for this, im pretty sure that i'd be able to install it as well as i know where to find a lot of the wires now. the door locks have a shorted wire and they lock over every bump, key turn or door close - so i have to figure that out, the power unlock only works 50% of the time =( gross
put in the front driveshaft today and beat my accel record of .5g with .65g on the dpic. also went into a grass field for 4x4 testing, everything is working perfectly. except 4lo which i think listens to the park/neutral switch which is no longer hooked up to the obs system. i need to find which wire that was and constantly ground it (i believe) so then i will be able to use 4lo. however this thing makes so much power in 1 that im not quite sure ill be using it yet (no rock crawling)
ran breathers from tranny and tcase to the top of the cowl so now i can DRIVE UNDERWATER
gettin sick of leaving 1 leggers all over the place so im going to start working on my 10 bolt any day now. i have the 8.5 truetrac already im just not sure which axle im going to put that in.
i have a spare 10 bolt
its the one the carrier blew on when i tried to do a burnout in big black. im considering using this because i can build it up and then just switch the axles with no down time. also the ebrake isnt working so i need to adjust that and probably rebuild the drums.
but its blown so i may not be able to use the bearings and gears... whereas the axle thats in my truck can just drop in the truetrac and keep going... but those bearings are 100k old so its more in need of a full rebuild as opposed to the spare axle which has 10k tops on all of the bearings
driving big black these days feels weird - like it needs a cammed 5.3.
believe it or not it pretty much handles the exact same way as the new truck but its just so damn weak it cant get out of its own way. the brakes actually feel much stronger than the ricer and its almost laughable. first fix will be to go with some stainless lines and a full bleed... then save money for something a little spicier.
bent up a bracket for the engine computer. not sema quality but does the job and can definitely deal with offroading. i also put a bunch of sticky padding under the computer to stop any metal on metal touching.
wired up the bypass and bluetooth to the radio and its sick. the storm works perfect. ive been using bluetooth headphones all summer (awesome purchase) and the radio is same deal. start truck hit play and without even taking it out of your pocket youre listening to your phones music. microphone for the phone works well and system quickly handles incoming calls etc
im running out of weather but im now at 100% operational pending a dyno tune.
If you're over 13 in while in boost, you better get out of it ASAP. That's leannnnnnn.
i figured thats why ive been babying it for now
