Page 4 of 5 FirstFirst ... 2 3 4 5 LastLast
Results 31 to 40 of 44
Thread: Wiring for Speedometer help!!
  1. #31
    Quote Originally Posted by NITROUS View Post
    Damn that sucks ChevyLee, maybe the switch is bad. Do you have another one? I'll look in the garage but I think my original one was broke.
    Yes i tried it with two switches. I have a brand new one allen gave me an the old one from stock. both are doing the same thing. No matter were i turn it to, it wont light up any of the gears that already don't light up.
  2. #32
    Apr 2007
    Willows, California
    Quote Originally Posted by ChevyLee View Post
    Try a different cluster.
    Pete
    2002 Chevrolet Silverado
    2002 Pontiac Trans Am WS.6
    2004 Dodge Ram CCSB Cummins Turbo Diesel
    1989 Chevrolet Silverado RCSB - Work Truck, Vortec 454 swap in progress :rocking:
    1972 Toyota FJ-40
    1963 Chevrolet Corvette Prostreet
  3. #33
    Quote Originally Posted by xXxSilveradoxXx View Post
    i did, same thing happened.
  4. #34
    May 2004
    The cluster doesn't matter because I've tried 96-2000 and they all work the same. ChevyLee, did you say you pulled the switch off and turned it by hand with it plugged in? Did you leave the NS switch connected to the old harness or is it all in the new harness? Sorry for all of the questions but this is driving me crazy!!
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
  5. #35
    Its also driving me crazy. It is connected to the new harness. i pulled it out, left it plugged in used my ratchet to turn it *it just so happen to fit in the hole*. I turned it and watched the orange light move, it would go P R then it would shut off, then come back on in 3 and 2 then shut off. I put it back on while it said it was in R but it was really in P. Moved it a few times and shut it off, then turned it back on and it went back to P hair pulling
  6. #36
    Apr 2007
    Willows, California
    I'm aware they all work the same, I was thinking that maybe some LEDs were out.
    Any update on the "rainbow" gauge wiring?
    Pete
    1972 Toyota FJ-40
  7. #37
    1940-94 Chevy/ GMC Trucks
    wish they made one for the 98
  8. #38
    May 2004
    Ya, that sucks! I wanted to buy a set for my truck a few years back and they said they probably wouldn't produce them.
    97 GMC, 2002 LS6.
  9. #39
    Needville,TX
    This is the info I got from worley.1
    I spoke to Jerod at Current Performance and he told me to take the Purple/white and Yellow/white wires from the factory harness going to the VSS and hook them up to the wires going to the VSS coming from the 4L60E which are Purple/white and Green/white on the harness that I have from Current Performance. he said that I need to scotchlock them. Purple/white to Yellow/white and Purple/White to Green/white. I know seems backwards. I will try it and let you know if it works.
    He tried this and it works.
    I tried this on my 4l80E and the speedo works! Im so happy!!
    89' GMC RCSB 6.0L LQ4, T56, 4.56 Gears
  10. #40
    Apr 2007
    Willows, California
    Quote Originally Posted by Kros383SS View Post
    So basically do this?
    Pete
    1972 Toyota FJ-40
