Page 4 of 5 FirstFirst ... 2 3 4 5 LastLast
Results 31 to 40 of 50
Thread: Part Numbers needed for an LS1 swap
  1. #31
    May 2007
    Here is an update on the conectors for the fuel filter as far as the price:
    Dorman Fuel Lines DOR-800-121 Dorman Fuel Line Connectors, Retainers & Repair Kit For 3/8 hose and line 1 $9.99 $9.99
    Dorman Fuel Lines DOR-800-120 Dorman Fuel Line Connectors, Retainers & Repair Kit For 5/16 hose and line 1 $9.99 $9.99
    Dorman Fuel Lines DOR-800-155 Dorman Fuel Line Connectors, Retainers & Repair Kit 12"x3/8 1 $12.99 $12.99
  2. #32
    Part number for oil pan oil cooler bypass/block off plate... http://www.ls1truck.com/forums/104117-post8.html
  3. #33
    Just found this... all the parts you need to complete an LS engine from the covers to bolts and sensors.... PN 19153789 Check it out at CrateEngineDepot.com
    19153789 Bare Block Completion Kit, Gen III
    Includes all parts to complete a Gen III bare block The kit includes:
    01-12575742 Valley Cover
    01-12561211 Cam Sensor
    08-11515756 Bolt
    01-12570471 Valley Cover
    01-12561243 Front Cover
    08-11515758 Bolt
    01-12614813 Rear Crankshaft Seal Housing
    12-12556127 Bolt
    01-89060436 Rear Crankshaft Oil Seal
    01-12574293 Rear Crankshaft Seal Housing Gasket
    01-12573460 Oil Galley Plug
    02-11588949 Oil Plug
    04-09427693 Water Drain Plug
    02-01453658 Transmission Alignment Dowel
    01-12561663 Water Drain Plug
    01-12556437 Camshaft Retainer Plate
  4. #34
    Mar 2005
    Atlanta, GA
    Does anyone have a cross reference number from other makers of this GM PN-
    PN 25312203
    It's the O2's I use for the '02 Camaro pcms.
    thanks,
    allen
    Standard motor p/n SG273
    1991 c1500. 5.3l and 4l60e swap in progress, next paint and body.
  5. #35
    Slimsilverado Guest
    I have a set of service manuels for all 2001 chevy truck, tahoe, and sub if yall need some part number just give me the part u r looking for and i can look it up i have 5 manuels that cover every nut and screw
  6. #36
    New PN update for rear main seal
    The new PN for for the rear main crankshaft seal only is 89060436
  7. #37
    Oil bypass / blockoff plate that was previously Fbody PN 12553210 is now PN 12577903. The seal to fit the plate is PN 12553210. FWIW, this new replacement plate does not have the provisions for tapping for a fitting. The boss that stuck out the side is no longer there.
  8. #38
    Dec 2009
    Part number for throttle cable bracket when using the truck intake is
    pn 89017380. comes with screws but if you are converting from dbw you may need to make yourself some inserts for the bolts. I used a fine thread 7/16 bolt and drilled and tapped for 6mm fine thread(original size), carefully drilled and tapped the bosses in the intake and lightly siliconed and screwed inserts in place. worked like a charm.
  9. #39
    Aug 2009
    Port Arthur, TX
    Dump question, where are these part numbers from? GM?
  10. #40
    Dec 2009
    Quote Originally Posted by 974door View Post
    unless specified most of these are gm part numbers that can be used to order from a dealer or many places online includings scoggin dickey and gmpartsdirect. otherwise they could be dorman or a company like that, but most places crossreference between brands.
