new CAI installed...
fit perfectly! just gotta change out the ugly blue couplers for red or black ones. i fired it up today and got the tach working...just gotta hook up the efans and get the exhaust ran. and shes done! finally....geez it only took 39 pages lol
did you have to put in any type of resistor for the tach? if so, what did you use?
i used a 680 ohm 1k resistor. works perfectly now.
so after talking with Redheartbeat he help me diagnose my trans issue. the 2-3 solenoid was either blown or not getting any power. so i dropped the pan today and bench tested the solenoid. it was good. checked the wiring and there was a break somewhere. after going through the entire harness i find this!
kinda hard to see the the blk/yel wire is disconected. i hooked it back up and voila! we have power! so i figure now i dropped the pan ill change the filter and fluid. also clean up the pan.
sweetness! getting closer to making that trip to GA!
Current project.
1957 Belair
SOLD!
http://www.ls1truck.com/forums/my-ga...rkwhite61.html
1999 Silverado RCSB
2004 LS6
4/6 drop
frame off rebuild
Great to hear the trans got fixed man!
95 C1500 LM7, built 4L60e, Circle D 3200, LT's, Nelson tune, open differential, 3.42, and LS1 e-fans. Tractionless
