NICE!!!!! i can't wait to back mine out my driveway.
so i finally got some new TYC oem headlights in. I think i might end up going with the crystal clear ones later. but i def like these better than the smoked ones that came with the truck. also got the cooling system hooked up. just waiting on my efans and i have to hook up the ls coolant temp sensor. truck still having issues with the trans but other than that it idles nicely and runs strong...in 1st gear lol
i also have an issue with the dash lights...anyone help me with this? all the bulbs have been replaced and all the exterior lights work on the truck now.
whats the issue? Your pic is all blurry. They arent working? Or too dim?
The hi beam indicator is stays on until I turn the high beams on. It's like if the left turn signal and hi beam wires were switched
did you plug in the plugs that go through the firewall on the passenger side, by the a/c stuff?
my dash lights were weird until i plugged those in. my left blinker indicator would just stay on & i think my high beam light was on also.
You kno what they are unplugged right now. I'll plug.em up later and ill see what happens
