Nope I told them that and they said 4x4 isnt a part of their harness. There harness is just the engine and tranny, they said the 4x4 "harness" on the obs truck is considered standalone. What I am trying to figure out is where that gets its power from because its not actually connected to the engine/trans harness. Sry myzterray for blowing up your build page, ill move this to my build page lol
PM sent regarding your AC setup .
I'm in the middle of sorting out this 4x4 wiring om my 98,it appears the PCM only wants to know if you are in 4WD or not,it has nothing to do with the operation of 4WD.Feel free to correct me if I'm not right(I'm used to that!).
Hey myz I know you are running the same headers as me, I put my drivers side on tonight and it just barely hits my frame rail. what did you do? get out the ole hammer and hit the header? lol or did you knock in the frame a little bit?
I had one doing that once and put a come-along on it and the opposite side frame and pulled it over. I didnt want to crush any pipes if I didn't have to.
Part Brand: Earl s Performance
Manufacturer Part Number: 9894DBHERL. Did these fuel line fittings work for you??
Other One is 9894dbjerl
