Page 34 of 44 FirstFirst ... 24 32 33 34 35 36 ... LastLast
Results 331 to 340 of 436
Thread: my first ls swap 1996 2 door Tahoe 4wd 385 Stroker to LQ4 cam headers **pics**
  1. #331
    Sep 2011
    Atlanta Ga
    Quote Originally Posted by silverado_lover View Post
    I spy Blue Moon?
    yezzir!!!! i went through a six pack during this process.
  2. #332
    Good taste in trucks AND beer.
  3. #333
    Sep 2011
    Atlanta Ga
  4. #334
    Sep 2011
    Atlanta Ga
    so today i decided to paint the piece in the back of the truck to make it look a little better.
    tools...
    masking lol...
    all done
    came out ok but i used the flat black and it looks faded. ill probably have to redo it with gloss or satin so it matches the carpet in the back.
    i also figured out the park neutral switch FINALLY!!!! seems like the switch was in the wrong position so thats why the back up lights didnt come on or starter engage. i traced the wiring and figured out that the ground on the starter relay isnt any good. so i will have to run another ground so it will work. only issue is that the gear indicator doesnt work. any ideas guys??
  5. #335
    Sep 2011
    Atlanta Ga
    got a lil delivery today..-6An fittings braided hose and fittings to connect to the trans case. also got my suspension..pro thane full polyurethane bushings! tomorrow i will hook up my new trans cooler lines. unfortunately the cooler on my truck doesn't have a screw on fitting to attach the hose so clamps it is!
  6. #336
    Here's to new parts!
  7. #337
    Sep 2011
    Atlanta Ga
    cheers!!!
  8. #338
    Sep 2011
    Atlanta Ga
    so i was able to hook up the new trans cooler today. braided hose lines were somewhat easy. just gotta be careful with the extra steel stickin out it will get ya fingers!
    old leaky lines
    removed clips and pulled out old lines
    removed old fittings
    old fittings vs. new fittings
    got the new fittings screwed in
    heres the trans cooler..
    old lines
    got the n fittings attached to the hose after some bloodshed lol
    hopefully this doesnt leak..probably upgrad this later to one with the correct fittings
    lines look pretty good in there
    here they are connected
    hopefully these things dont leak. i took off all the wiring so i couldnt fire it up..gotta figure out how to get the transmission to align on the crossmember its a PITA with only one jack. damn adjustable mounts!
  9. #339
    Jun 2009
    Caledonia, MI
    I have a few questions about your harness. Im working on my old harness right now and cant find exactly where the 4x4 harness ties into the engine harness...it seems as its basically a "standalone" harness. I need to put the 4x4 harness in with my nelson harness. If you have any tips lemme know!
  10. #340
    Sep 2011
    Atlanta Ga
    Quote Originally Posted by HPICamaroSS View Post
    I haven't paid much attention to the 4x4 part of the harness because I'm probably doing away with the 4x4 anyway.
