ok so since i got the truck running i been cleaning up everything and noticed a leak. my trans cooler lines got kinked and now leaks whenever i start up the truck. so i just ordered the 1/4 to 6-an npt fittings for the trans case 45 degree -6an fittings and 10 feet of steel braided hose. i think that should be enough. also i noticed my oil pressure is really high. the adapter i ordered from s and p had a bunch of extra holes. what adapters are u guys using for the oil pressure sensor in the obs. once i install the trans cooler lines ill take some pics.
im also selling my blacked out corner lenses. $10 plus shipping..
one is chipped a little
oh ok cool. as far as the fuel lines it depends on how you want to set it up. you are going to need the corvette filter first. then you can either go with the steel braided hose and an fittings or just regular rubber hose and clamps. i did the rubber hose and clams because i was going by the obs to lsx thread, then i did some research and found out the an fittings with the steel braided hose is the best way to go. ill be changing mine soon.
heres a link to the filter
http://www.amazon.com/Original-Engin...1333464&sr=8-1
ok thanks for all the great info you have been so much help
finally finished installing my carpet..did the cargo area. also been cleaning all the interior plastics with mr clean. came out pretty good.
before
after
after a little mr clean
now i just have get that piece behind the back seat redone. its extremely dirty...i have a a few engines and countless tools and parts back there.
I spy Blue Moon?
95 C1500 LM7, built 4L60e, Circle D 3200, LT's, Nelson tune, open differential, 3.42, and LS1 e-fans. Tractionless
