Page 30 of 44 FirstFirst ... 20 28 29 30 31 32 40 ... LastLast
Results 291 to 300 of 436
Thread: my first ls swap 1996 2 door Tahoe 4wd 385 Stroker to LQ4 cam headers **pics**
  1. #291
    Sep 2011
    Atlanta Ga
    You don't want a K&N filter anyways. The oiled filters have a tendency to foul the MAF. Get a cleanable/reusable dry filter.
    yea so i heard. ill probably pick up an ebay filter. this one looks pretty good
    http://www.ebay.com/itm/Bully-Truck-...item415e7dc19e
  2. #292
    Sep 2011
    Atlanta Ga
    i swear i have the longest running swap on this site lol. just relocated from southern cali to henderson nv which is right outside vegas. i cn see the strip from my balcony. once good ol uncle sam pays up ill finally have this thing running. its pretty much ready to go i just have to go down to the local stealership to pick up the starter bolts. i turned the key to make sure everything else was good to go and i have a few issues. fuel pump is not coming on nor am i getting a reading on the dash.. neither is the blower for the hvac. any ideas??
  3. #293
    May 2010
    Galveston, Tx
    I'll check to see if I have any starter bolts laying around...
    95 C1500 LM7, built 4L60e, Circle D 3200, LT's, Nelson tune, open differential, 3.42, and LS1 e-fans. Tractionless
  4. #294
    Sep 2011
    Atlanta Ga
    Quote Originally Posted by silverado_lover View Post
    thanks but i went to the stealership and picked em up for $4 a piece. starter installed and wired. now i still gotta deal with this stupid pns switch because its not cranking. this whole time for whatever reason i thought i had to put a ground wire to the starter. i jumped the wire and it engaged but not when i turn the key
  5. #295
    Sep 2011
    Atlanta Ga
    SHE LIVES!!!!!!!!!!!!!!!!!!!!!!!!!
    after i got the starter hooked up i was compelled to get this thing going. i couldnt figure out the pns switch wires so i just ran a hot wire to the solenoid and got it to activate. i figured out the fuel pump issue. gave it some power and it started. im probably going to have to take it to a shop to get the pns switch fixed. also gotta get the exhaust ran and shes done! truck just has open manifolds right now thats why its so loud. also i said ls1 its a 5.3
    http://s1105.photobucket.com/albums/...=VIDEO0053.mp4
  6. #296
    Jan 2012
    warwick ny
    Nice job.What was the problem you had with the fuel pump?
  7. #297
    Sep 2011
    Atlanta Ga
    theres a little grey plug that comes from under the truck that connects to another plug connected to the fuse block. its what give the fuel pump power and powers the dash gauge. it was one of those minor overlooked things.
  8. #298
    Sep 2011
    Atlanta Ga
    http://www.gmtruckcentral.com/wiring...1996tahoe.html
    found this awesome site today. helped me alot with the pns switch. only thing i cant figure out is where the transfer case control module is. diagrams say under left side of dash but theres so much shit going on under there i dont know whats what. any help?
  9. #299
    May 2010
    Galveston, Tx
    I was trying to browse that site for info on the pns switch...couldn't find the PDF that had the info. Hook a brotha up with a link to it?
  10. #300
    Sep 2011
    Atlanta Ga
    well theres no pdf for the pns switch. i used several. (back up lamp, starting system, transmission etc) i just looked through all the schematics that had the pns switch diagram and made notes. basically through my research this is what ive found out about the pns switch.
    thick yellow wire comes from dash
    purple thick wire goes to relay in fuse box
    lt green power reverse lights
    yellow goes to pns output in c100 connector
    pink is ignition
    black is ground
    so i think once you find those you should be good. my truck is 4wd so i have a second lt green wire that gooes to the tcc and to the tranfer case control module. i cant find my test light right now so i havent been able to find out where im losing power. even with everything hooked up the starter solenoid isnt engaging. so i need to trace the wiring with a test light and figure it out.
