Got them today with a set of black custom made taylor wires. The headers look great but I wish they had a 3/8" flange on them. Now that I have a set maybe it's time to buy a stainless header kit and build some long tubes. I ended up getting the same set that vettetruck89 purchased. I held them up by hand to the heads and it looks like it might be a little tight on top of the rear passenger side eccentric. I'll know better once installed. Not much left do do but the wiring. I built a custom stainless radiator cover/support and installed a hayden transmission cooler with all 3/8 swedgelok stainless hoses and fittings that adapt to the front tubing. An A/C belt, hoses, radiator hoses and some fluid and it's about over. If things go as planned at work, I'll be at the strip sometime late April.
97 GMC, 2002 LS6.
1991 GMC Syclone #1428
- You may not post replies
- You may not edit your posts
