Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 30 of 47
Thread: Truck isnt getting spark anymore. im at the end of my rope lol
  1. #21
    Quote Originally Posted by banker099 View Post
    Been a while since i have done this, but try grounding the black wire on the large plug that goes into the main plug on the coil packs, then check for spark.
    will do man thanks. what would cause this issue?
  2. #22
    wichita falls, tx
    Bad ground or possibly another sensor keeping the plug from getting the ground signal...cam sensor, map sensor, etc may have a broken or shorted out wire in the harness
    Intro Radicalli's
  3. #23
    Didn't work lol, tomorrow im gonna go over the harness.
  4. #24
    Apr 2013
    Houston
    Have you tried a new pn switch? Or moving the selector inside the switch and having some one try to start it? Any possible way it could've done something to VSS when drive shaft came out?
  5. #25
    Yes ive changed it out, as far as I know the vss wont stop it from starting, but no it looks fine
  6. #26
    If it cranks the PRNDL is fine. My bet is a broken wire in the harness somewhere.
    Pittsburgh, PA
    Light it on fire
  8. #28
    Quote Originally Posted by George C View Post
    Light it on fire
    that aint no shit im almost to that point, so even though it is tuned, and I switched out PCMs to make sure I didn't fry one, is it possible that the vehicle theft system in the BCM is causing this, there is no security light on, im just asking should I do a security relearn even though vats is off
  9. #29
    Jun 2011
    Rogers, Ar
    You need to see if the computer is reading rpms, do the injectors pulse? That will give you a starting point. If the security light goes out with ignition on its fine.
  10. #30
    Mar 2013
    Long Beach California
    i asked a question that was already anwered.. nevermind this post. lol
    CALI LEGAL ENGINE SWAP!
