Page 3 of 6 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 55
Thread: Project Sucker Punch
  1. #21
    Mar 2011
    Gibbstown, NJ
    Quote Originally Posted by dmcdevin View Post
    Got the drop kit in last week! Thanks! Great guy to do business with!
    No problem, I'm glad I could help
  2. #22
    Mar 2011
    Gibbstown, NJ
    Just some photo updates that brown santa delivered to me.
    FAST 92mm Throttle Body
    Russel -6AN Fittings
    4:56 Gear's From Ron's Machine Service, Big Thanks to Ron and entire crew
    Install Kit
    Energy Suspension Sway Bar Kit
    Energy Suspension Trans Mount
    Energy Suspension Cab Mounts
    Russel -6AN Line
    More Fittings and random connectors
    243's Acid dipped and Sonic Washed
    243's On Milling Machine
    Done And Shiny
    Nice And Flat
    2001 ECSB Z-71: 7.0L LS7, Kook's LT's, True Duals, RPM Tune, F.A.S.T. Intake/TB, YANK TT3000, 4:10's, G80, AWD Swap, 160-Stat.....
    Slowest in South Jersey ..........SOLD :-(
    2012 GMC Sierra Z71 CC: 6 Speed, 3:73's, G80, Back up DD...........SOLD
    2000 RCSB Shitbox.......370LSx/Built 60e/4.56's,EATON Posi, CAI,3" SLP Exhaust, DD.......Build Thread http://www.ls1truck.com/forums/my-ga...ker-punch.html
  3. #23
    Mar 2011
    Gibbstown, NJ
    370 Motor back form the shop
    Rear cover installed
    Cam installed ( TSP 224/228 .581/.588 114 LSA )
    Valley cover installed
    Short Block
    Heads installed (243's with patriot gold dual springs)
    New GM Updated Rockers
    Comp Cams Hardened Push rods
    Rear Leafs re-done with Energy Suspension bushing's and bottom overload removed
  4. #24
    Mar 2007
    Newark, Delaware
    How much those pistons run you? I didn't know GM sold oversized pistons.
  5. #25
    Sep 2011
    Lookin good , why didn't you port those 243's!?! Looks like you have access to cheap machine work like I do lol! Did you get the rotating assy balanced? How high you planning on twisting it? Which injectors you using ?
    99 rcsb silverado...... boosted.
  6. #26
    Jul 2012
    Nice build thread.
    Tony
  7. #27
    Mar 2011
    Gibbstown, NJ
    Quote Originally Posted by Beatdown Z View Post
    I wanna say they were $65 my cost, that was with piston,wrist pin, and pin clips. They are GM stock replacement for LQ9/LS2 motors, due to the fact that GM made the bore sizes between 4.000-4.004 (LQ4)-4.013-4.020 (LQ9/LS2)..... Either or the piston's are available over the counter Stock Replacement Piston size from GM is 4.000, Optional GM Replacement piston size is 5mm oversize which equates to a piston over bore size of 4.020th's, the new displacement with those pistons in the block comes out to 368ci......So I rounded it up some to 370ci lol
    I used this Formula to achieve my Displacement
    It Works like so for any motor...........I used my engine info for my application. Everyone else's will be different........................ Bore Squared (4.02 x 4.02) = 16.1604 Divided By (4) Equals (4.0401) Times by Stroke (3.622) Equals (14.633242) Times by (8 PIE "25.12") "pie equals 3.14" so (8 Times 3.14 "pie" = 25.12) Equals 367.58703 Cubic Inches Of Displacement
    Quote Originally Posted by jansen View Post
    Just because I don't tell everyone they are ported doesn't mean they were ..........they got a very very mild scuff and smooth, basically just a quick puff with a flapper wheel to make them look pretty. I didn't want to spend the extra $$$$ on porting them, because I will be swapping over to LS3 heads very shortly that WILL BE ported. No balancing on the rotating assembly, It was all new from GM when I bought the crate motor, But it was checked for accuracy. (Stock LS2 bottom end btw). I'm shooting for 435-465hp on motor and as close to 400rwhp+ as possible. I have a stock TBSS intake with the FAST 92mm on it and stock TBSS injectors that I will be using for now until I get it squared away..........I did use TOTAL SEAL RINGS and they did get gapped for juice...just in case I don't reach my 12sec goal N/A
    Quote Originally Posted by TDFDiesel View Post
    Nice build thread.
    Thanks!! Make sure to keep checking back for progress and updates
  8. #28
    Mar 2011
    Gibbstown, NJ
    Some more updates
    Russel 3/8 Quick Connect Fittings that I used on the fuel rail/fuel filter/ gas tank
    Rear backing plates and drums cleaned and prepped for my swap to 15x10's for the rears ( parts supplied courtesy of Blacstar, thanks bro. Assembled with help from some pics from 02camaross )
    Rocker Rot
    And the new rocker replacements....It's better to spend the money on the more expensive one's the first time then buy cheap units and replace them twice
    Rear leaf springs cleaned and painted with Energy Suspension bushing's installed
  9. #29
    Mar 2011
    Gibbstown, NJ
    All cleaned up before the Stevie Wonder treatment
    After the Ray Charles treatment
    The reason your shifter arm breaks......Need that little tit on the bottom to stop it from over extending past first and winding up in your lap.
    The 415K+ 4.8 finally sh!tting the bed!......click pic for video
  10. #30
    Mar 2011
    Gibbstown, NJ
    4.8 coming out
    And out it is
    The reason the truck had vibrations and the converter shuttered, 1 broken bolt, 1 backed almost all the way out, 1 finger tight.....it came that way lol ( Jansen was right about the trans being eff'd up haha)
    Prepping the truck and motor....someone put the AC tensioner on upside lol....was corrected before install lol
    In ya' go!!
    TBSS intake with FAST 92mm
    Finished product
    IDLE VIDEO!..............Truck has stock junk on it (mani's and cats.....JUNK!!!) waiting for the LT's to come in.
    http://s1228.photobucket.com/user/Mr...c894c.mp4.html
