Page 3 of 9 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 84
Thread: 95 z71 6.0 swap
  1. #21
    sweet! Post up pics
    1979 C-10 Big 10 LSx powered BUSTED REAR END
    1994 K1500 05 L33/60E swapped
    2005 Yukon 4x4 factory 4.10's
  2. #22
    Broken Bow, OK
    I just noticed looking at your pics, that engine is not a 2004. It has EGR and DBC throttle, probably a 2001 since it has alloy heads. What color are the plugs on your wiring harness for the PCM BLUE/RED or BLUE/GREEN and what PCM do you have for it?
  3. #23
    Nov 2010
    Durant, Ok
    Wink
    Quote Originally Posted by PitchBlackC3 View Post
    Yea the guy I bought it from was gonna be putting it in a old impala, and he said the throttle body he got off of a early 5.3. And the harness that came with the truck was cut so idk what color the plugs are. The computer I got off eBay is a 5.3 computer that has been flashed with vats removed and stuff, its not a 0411 I don't think, is it gonna work? The harness I had found on eBay and it was reworked by hot wire auto
    Josh ----- 95 Z71 ecss -6.0 swap finished 10k miles ago, nelson tuned, built tranny, 2800 converter, 4.56s truetrac
    2000 z28 a4 longtubes, true duals, ported throttle body, ls6 intake, slp lid (lost in divorce lol)
    79 camaro small block street car 11.60 @ 116 (sold)
  4. #24
    Nov 2010
    Durant, Ok
    And I will try to get pics up soon!
  5. #25
    Mar 2011
    hey i just joined the site and was wondering how the swap was going. I also have a 95 Z71 and im wondering if it would be worth it to put a ls1 or ls2 in it.
  6. #26
    Nov 2010
    Durant, Ok
    Quote Originally Posted by countryx18 View Post
    Hey man welcome to the site. I would have had the motor/tranny in this last weekend but I forgot to order the standard length flywheel bolts. I had the long bolts with the spacer to mate to a th350 converter. So I'll hopefully have the bolts in by this coming weekend and I'll get it all in and start the hard work lol. But to answer your question, I'm not even close to done with the swap and I can tell you yes the swap will be worth it!
  7. #27
    Nov 2010
    Durant, Ok
    HELP!!!!!!!!!!!!! An update: I have been trying to mate the motor/tranny, and I am using my 95 transmission. I have a trail blazer torque converter. At first I had A dished flywheel and the spacer on the motor bc it was mated to a turbo 350. well I took the spacer off and put the dished flywheel on and the flywheel met the torque converter, and there was still probably a half inch between the bell housing and the motor. So I thought I figure I needed a flat flywheel, so I traded a buddy for a flat flywheel off of a 5.3. And put the flywheel on the motor and it was very close to the back of the engine, and it was actually pushing back on the starter. What is going on and what flywheel/starter do I need?? Any input is appreciated, I am without a vehicle and need my pickup going asap
  8. #28
    Broken Bow, OK
    Are you sure that your TQ converter is engaged completely?
  9. #29
    not sure but maybe you need the 4.8/5.3L dished flexplate with the spacer on the transmission side of the flexplate. Mount the converter to it by hand first before trying to stab the trans in. Be sure the bolt holes line up and the pilot is engaged. This is assuming you have the late model 6L with the short crankshaft, end of crank almost flush with the crankshaft seal. If the crank hangs out of the seal about 1/2" you have the 1999-2001 early style 6L and you will have to slot the bolt holes on a flat Gen3 flexplate or drill new holes.
  10. #30
    Nov 2010
    Durant, Ok
    Yes sir that was the first thing I checked
