Results 21 to 30 of 31
Thread: Amp to door speakers?
  1. #21
    Replace the 4x6's with 5.25's. Only a little trimming.
    Quote Originally Posted by lo-lyf View Post
    I've done many pairs of 6.5's only issue is mounting depth, 4x6's (or any oval in my opinion) is a waste. The only 4x6 I've ever liked are the plate type that have a 4" round and a tweeter.
    Probably not unless you are using 4g to each from a 1/0 and distribution block or 4g each from the battery. The 400 would probably be okay on good 8g.
    So you think i should run 0 gauge then?
  3. #23
    Wichita Falls, TX
    Quote Originally Posted by 6.0vortecchevy View Post
    If you are wanting to only run one wire to a distribution block, I would. You could also get away with running one 4g for the sub amp and an 8g for the mid/high amp, the choice is yours.
  4. #24
    Jun 2010
    West Texas
    Need to also make sure your alternator puts out enough. My set up draws 880 watts RMS so it calls for bout 130 amps for the sound system plus more for the truck to run. So I put in a 200 amp alt.
    RUN WAT U BRUNG!!!!
  5. #25
    Do you guys change the alternators alot or is that just in your case?
  6. #26
    Jun 2010
    West Texas
    It depends on how much juice you need, I mean how big those amps are.
    RUN WAT U BRUNG!!!!
  7. #27
    Ones 400 and the other is 1000.
  8. #28
    Jun 2010
    West Texas
    Rms?
    RUN WAT U BRUNG!!!!
  9. #29
    Oh im not sure ill have to take a look, but has anyone heard of a kicker kx300.2? Are they any good?
  10. #30
    Jul 2009
    Just fyi i love my JL evolution C2's!!!
    04 Silverado Z-71 Extended Cab
    Magnaflow, 10.4 TV 50 wires, tr-55ix, Synthetics, HID's, JL audio, 33.5", leveling kit, tuned, CAI, vette servo, cam, valve job, pacesetter. 9.3@77.5 and 14.5@93.4
    06 2wd
    custom cam, tune, 3.73's, servo, HID's, 10.4mm wires, long-tubes, CAI, magnaflow, 2.5" shackles, Circle-D 3200, UD, JL Audio 4.1, Alpine 5ch
