Where is the OP sensor? Mine is doing the same thing and when I check the Interceptor gauge, it reads 120!!
+1 on replacing sender.
2005 crew cab, new crate lq9 with comp 212/218, 558/563 on 115 cam, 80mm t.b. coated long tubes, off road y, flowmaster cat back, dynomax bullet, ngk plugs, msd wires, k&n cold air kit, 4.10 gears, auburn pro lsd, transgo shift kit, nelson drive tune, trailblazer i-6 torque convertor, anzo lamps, ss front bumper, z71 tahoe rear bumper, debadged, kenwood touchscreen with headrest monitors, JL components, coaxials, sub, 5ch amp. bell tech 2/4 drop. 22x10 ss wheels with 285/35/22 bfgs.
I would mention that the sending unit needs a special socket, but since its Jay and he is too much of a sissy to work on his own truck, I am gunna leave it up to his expert mechanic to go ahead and figure it out.
But since this is Taylor's thread: Taylor, when you replace the oil sending unit in its location as described by Nathan, you will need a special socket to remove it.![]()
What does it mean when the oil pressure gauge keeps boucing around at idle? At WOT i hit 80 psi.
Last edited by cjriojas; 11-03-2009 at 12:34 AM. Reason: i forgot the freakin question mark, alright!
'02 Silvy: Z71 EC Step Side 5.3L Nelson tuned
2013 GMC Acadia: SLT1 Carbon Black
1976 Corvette Stingray: Trying to save it, progress is slow.
^Ricky's Sweet PS Skilz
09/21/2010 02:31 <danger_ranger83> I'm not really worried about the looks...I want it to be fast and ugly...bc no one wants to get outrun by something ugly
