your going to need bigger injectors, them stock 24#'s won't cut it.
11' Sierra 6.2 NHT
14.46@91 Stock
89' Mustang LSX
10.35@130 pump gas LQ4
Knothead Racing
ok so if my 24# injectors aren't big enough, which injectors should i get?
2003 GMC K1500 ECSB running an Iron 383 Stroker ......
Believe the ls6 makes power up higher....for a daily driver/tow rig you want it lower in the RPM range
