Ask and you shall receive!
* AC Delco EP381 in-tank pumps. $69 each at
FE0114 - Electric Fuel Pump
* Pollak high psi tank selector valve, this is a direct OEM replacement (JC Whitney p/n ZX812705U) $83
* Fuel selector switch from an 87,
replaces existing dash switch (AC Delco p/n D7089C) $11.50 at rockauto.com
* Corvette filter/regulator if running a returnless/1 line system (WIX p/n 33737) $34 at rockauto.com
If you don't already have in-tank pumps, you'll need sending units:
* Dorman p/n 692027 for the driver side, $94 at rockauto.com
* Dorman p/n 692044 for the passenger side, $101 at rockauto.com
To make the connections at the filter/regulator:
The inexpensive way:
* 3/8" female connector (Dorman p/n 800121) $6.30 at rockauto.com
* 5/16" female connector (Dorman p/n 800120) $6.30 at rockauto.com
* 3/8" x 12" double ended male connector (Dorman p/n 800120) $8.20 at rockauto.com
The "nicer looking" way:
* 3/8" to -6AN straight fitting, Russell #640850
* 5/16" to -6 AN straight fitting, Russell #640860
* -6AN to -6AN union, Russell #660350
* -6AN tube sleeve, Russell #660650
* -6AN tube nut, Russell #660571
And be sure to use a good quality high psi fuel pressure hose for connections, not regular fuel line. And use smooth stainless fuel hose clamps that look like these:
If anyone see's something I forgot let me know, and I'll edit the post.
