Results 21 to 30 of 36
Thread: 79 k5
  1. #21
    Anaheim Hills, CA
    Quote Originally Posted by 1 bad blazer View Post
    i should receive the pcm tommorow , thats when i''l hack the harness up . by the way here's some pics of my old truck 87 chevy 5.3 700r4 ,3.73 posi holley
    YouTube - 1-87 Chevy BURNOUT 2
    YouTube - 1-87 Chevy at Angelton Raceway
    Nice!!!! Too bad my POS speakers dont work.
    ...........Workin' on it...........
  2. #22
    that's one thing i did do , was grab mass air , fuel tank, throttle cable , air box and tubingand all the acc's . this makes the swap much easier, and thanx for the help guys.
  3. #23
    Dec 2008
    Hugo, Ok
    but if you have pcm re did cant ya whip out the emissions stuff and it run better?
    how you wire your cruise?
  4. #24
    Anaheim Hills, CA
    Yes, you can remove all of the emissions. But there are certain sensors that are just better off keeping. Trial and error, win some, loose some.
  5. #25
    Dec 2008
    san antonio TX
    i really dont want to use the stock fuse block from the 03 tahoe, i want my 82 c10 to have a clean engine bay. but ill take your advice since youve done it already, ill get as much as i can. you started from scratch on the wire harness , how willl i get the truck harness and the engine harness to work together on the truck. sorry if your getting bored with the questions.
  6. #26
    Anaheim Hills, CA
    Naw man, I dont mind the questions........I will have plenty of my own.
    The ECM just needs a power wire (orange), remote wire (pink) and a ground wire (black). The rest of the engine harness just relays data and signals to and from the brain. The fuses are for your accesories (lights, radio, wipers, rad fans, fuel pump and so on). I did fuse the power wire to the ECM too. Maybe not needed, but what the heck. So, in short, the fuse block will be totally seperate from the rest of the "Engine" harness. Hope this helps.
  7. #27
    Dec 2008
    san antonio TX
    im going to a local book store tommorrow to find a book on how to wire an ls based engine, hopefully i find something.
  8. #28
    Anaheim Hills, CA
    I guess I did not answer you question right.
    Do you plan on using the stock gauges? If so, I am not sure how to adapt those to the newer senders. If you use aftermarket gauges, you can use new senders that are compatible with that gauge.
    I cant answer your question about merging two different harnesses. But I am pretty sure the new ECM will not support the existing gauges.
    Sorry, not much help there.
  9. #29
    Anaheim Hills, CA
    I will search around too. I will go hrough this in the next few months on my '72. All I need to figure out, is the gauges. Everything else will be stand alone from the ECM and the harness.
  10. #30
    Dec 2008
    san antonio TX
    yeah you answered my question, but i want to get a book to help because i dont want to bother you to much. oh and yes i plan on using the stock gauges.
